Old 5th February 2010, 07:37 PM   #1
tommy1 is offline tommy1  United States
Default Need Help About Speaker Relay!
Hello everyone,
Does the speaker relay turn on with out the output TRANSISTORS?
Thank you!
Old 5th February 2010, 08:14 PM   #2
nigelwright7557's Avatar
The output transistors turn on before the relay does.
There is usually a couple of second delay from when teh amp is powered up until the output is connected to the speakers.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 5th February 2010, 08:46 PM   #3
Thank you for relying.
What I mean was "can the relay kick on if the OUTPUT TRANSISTORS WERE TAKEN OUT OF THE CIRCUIT BOARD?"
Without the OUTPUT ...C: 33 Volts, Bass: 32 Volts, E: 0 Volts. When I put the OUTPUT back in the circuit board
then the Bass turns to be zero Volts ????
Old 6th February 2010, 12:17 PM   #4
EchoWars's Avatar
Depends on what the removal of the transistors does to the feedback loop. So the answer here is 'maybe'. A schematic of your amp would help.
Old 6th February 2010, 02:14 PM   #5
maxpou is offline maxpou  Canada
maxpou's Avatar
Hi Tommy1,
why do you removed the output transistors? Maxpou
Old 6th February 2010, 02:29 PM   #6
5th element's Avatar
If the relay control circuit is designed properly it will not turn them on if there is any appreciable DC on the output of the amplifier.
An amplifier without any output transistors might show one of the rail voltages on the output, this would stop the relays from closing.
On the other hand, if the output transistors had blown and the rail fuses blew as a result, then there might be no DC on the output and the relays will close. That is if the relays and control circuitry are not powered after the amplifiers rail fuses.
What is it that's gone wrong?
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 6th February 2010, 04:58 PM   #7
...ansewering to MAXPOU. I removed the output transistors for safety. However, the Amp is working execpt the relay does not kick on because of the IC C1237.
I got the audio output before the relay. So far, I have replace the UPC1237HA.
Thank you so much to all the friends in this forum !
Old 8th February 2010, 09:10 PM   #8
what make and model amp is it?
Old 8th February 2010, 09:53 PM   #9
The model # a-501 made by API
Old 8th February 2010, 10:06 PM   #10
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
The UPC1237 will keep the relay open if there is a little DC on the output. Can you measure the output DC with no signal?
jd
/Another new issue: Linear Audio Volume 3!
speaker protection relay trouble lordy Solid State 21 23rd October 2004 04:08 PM
Replacing speaker protection relay chrisk Parts 1 9th February 2004 10:38 PM
Speaker Line Relay poulkirk Everything Else 3 24th September 2003 10:41 AM
Speaker Relay thylantyr Solid State 7 25th April 2003 06:03 AM
Speaker protection relay PH104 Solid State 4 20th February 2002 07:46 AM
Page generated in 0.13003 seconds (84.15% PHP - 15.85% MySQL) with 10 queries
