When used in a circuite like this does the drain resistor value have a large
effect on distortion. The reason I ask is I would like to run a 2sk170 in a circuite like this but at 5ma with a 200ohm drain resistor. I realize the gain will be a lot less but would the distortion be higher as well? |
#2 |
5mA passing 200r source resistor will give Vgs=1V.
You might find it difficult to source a k170 that passes 5mA @ Vgs=1V. I think the highest Vgs a BL will hold will be about 0.2mV @ 5mA. I somehow doubt a V grade will give you what you require.
regards Andrew T. |
#3 |
I was asking about the drain resistor not the source resistor. Let me ask it a little differntly. If I have a jfet with the source grounded and only need .01v output
would I have more distortion if I used a 100ohm drain resistor or a 10kohm drain resistor. |
#4 |
a 200r drain resistor will drop 1V from supply to drain.
This limits your maximum +ve voltage on the output to a bit less than 1V, you might get a maximum of 0.6Vpk just before the signal clips. That would be an output of ~400mVac with large distortion. I don't think that is what you want. That's why I thought, mistakenly, that you meant source resistor = 200r. If you have the source grounded and the gate referenced to the same ground, then the FET will try to pass Idss. This will cause a voltse drop across the drain resistor. It would be normal to adjust the drain resistor to get a DC output voltage of about half the supply voltage. Not many designers run their FETs ~ 100% of Idss. They are more usually run between 20% and 90% of Idss.
regards Andrew T. Last edited by AndrewT; 4th February 2010 at 11:49 AM. |
#5 |
supply voltage must be increased to 15v....
| JFet matching and measured distortion - Part1 | h_a | Solid State | 22 | 27th March 2009 06:41 PM |
| JFet matching and measured distortion - Part 2: LTP | h_a | Solid State | 27 | 27th March 2009 05:40 PM |
| Simple Low Distortion JFET Buffer | wrenchone | Solid State | 21 | 29th January 2007 08:16 PM |
| Dumb JFET Question | EchoWars | Solid State | 2 | 3rd March 2004 09:08 AM |
| Page generated in 0.06807 seconds (84.55% PHP - 15.45% MySQL) with 11 queries |
