High Voltage LED
High Voltage LED
Old 3rd February 2010, 05:29 PM   #1
JammyBStard is offline JammyBStard  United Kingdom
JammyBStard's Avatar
Default High Voltage LED
This is probably a stupid question but googling is getting me nowhere; I'm building a Phono Pre-amp it's going to be battery powered by 8x 9v Batteries at 36v (regulated to 24v). as it's battery powered every milliwatt is precious and the current limiting resitor for the power LED is going to burn over a watt, is there a simple way of driving a regular LED from this relativly high supply voltage without burning-off a load of energy into a resistor?
Old 3rd February 2010, 05:33 PM   #2
cliffforrest is offline cliffforrest  United Kingdom
High Voltage LED
There is no magic solution to this except by using a switch mode voltage converter. Even then the efficiency gain will be marginal and the complexity relatively great.
Are you sure you need a high current in the LED? Try it at 100uA - you will be surprised how bright they can be.
Incorporate the LED into one of the amplifier's biasing circuits so that its current is not extra to requirements.
Old 3rd February 2010, 05:40 PM   #3
ashok is offline ashok
ashok's Avatar
High Voltage LED
Originally Posted by cliff View Post
.........Are you sure you need a high current in the LED? Try it at 100uA - you will be surprised how bright they can be.
That's the way to do it. There could be several places that you could introduce the LED without affecting the performance much. As Cliff says it needn't be very bright if it's just to indicate 'power on'.
What's your basic circuit diagram like ?
AM
Old 3rd February 2010, 06:14 PM   #4
A bit like this:
Old 3rd February 2010, 06:53 PM   #5
High Voltage LED
OK.
In that case there is no perfect bias point.
You could put it at the top end of the first 24K load, but then would probably need a second decoupling cap.
Or simply use a 100K series R across the 24volt rail. ~ 200 uA current lost - I bet it is bright enough!
Old 3rd February 2010, 06:57 PM   #6
Sounds like a plan!
Old 3rd February 2010, 07:01 PM   #7
burbeck is offline burbeck  United Kingdom
how about in series with the B+, after the battery, this would require the current drawn from the battery to be any thing up to 30mA or so.
this way there is the same overall power dissipated/wasted in the regulator or regulator and led.
dissadvantage is there is a led drop to the positive reg so battery will get to its end point sooner.
well somthing to think about at least
regards
bob
Old 3rd February 2010, 07:05 PM   #8
High Voltage LED
Good one! Yes, I've done that in the past, but with a R across the LED to reduce the brightness.
It "loses" a couple of volts, though. But here that would be no problem at all.
Old 3rd February 2010, 07:10 PM   #9
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
High Voltage LED
You may use a LED as a reference voltage source for your voltage regulator you are going to implement.
The Devil is not so terrible as his math model is!
Old 3rd February 2010, 07:55 PM   #10
Andrew Eckhardt is offline Andrew Eckhardt  United States
I recently made a battery operated white noise generator. I stuffed a SLI-580UT3F in the collector circuit of the emitter-follower portion of the output stage which is biased at about 100uA. It's plenty bright. Some of the newer high efficiency red diodes glow impressively bright just with the .5mA diode drop test current of a DMM.
High Voltage LEDHide this!Advertise here!
LED on mains voltage? AndrewT Parts 43 19th March 2014 12:33 PM
Why high voltage Fets when low voltage types gives less distortion? Circlomanen Pass Labs 21 9th December 2009 10:43 PM
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 10:43 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 02:32 PM
