Old 2nd February 2010, 01:13 AM   #1
Default Is this consider a push pull amplifier?
I just bought a power Amp DIY circuit recently. Just want to start to learn everything about power amp. Does the part that i quoted with a box consider a push pull amplifier?
thank you.
Old 2nd February 2010, 02:44 AM   #2
Attachment 156387
thank you.
Push-pull back in the tube days (still for some) was a center tapped transformer with 2 power tubes driven 180 degrees out of phase. When 1 tube 'pushed', the othe 'pulled'. What it implies is separate devices (tubes or transistors) for the positive and negative peaks. The section you circled is the driver section for the output devices. Q1 and Q3 form a Sziklai pair which is configured to have some voltage gain since the opamp "IC" can't deliver the full voltage swing by itself. Q2 and Q4 perform the same function for the negative part of the signal. Overall gain of the amp is R4/R10 + 1. Adequate but not impressive as power amps go.
Old 2nd February 2010, 02:45 AM   #3
bear's Avatar
That part provides current and voltage gain and drive for the outputs, and creates the required bias for the output transistors.
The output transistors are doing the "push pull" part, but there is also a "push-pull" output circuit inside the opamp.
If you want to learn everything about power amps, read some text books and everything in this forum - then you will be either expert or very crazy person?
_-_-bear
PS. no need to buy "circuits" schematics - there are so many here and online.
Kits are also here and online.
Take a look in the "Pass Labs" section for some nice amps and sources of PCBs and parts... have fun!
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 2nd February 2010, 03:36 AM   #4
thanks for all the replies. So do u mean that Q1 and Q2 work as a push-pull?
Old 2nd February 2010, 08:42 AM   #5
hi,
can i say that the Op-Amp works in a way of negative feedback?
thank you.
Old 2nd February 2010, 08:47 AM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
hi,
thank you.
The opamp itself works open loop, but the whole ampolifier has neg feedback via R4 and C7: a part of the output is fed back to the neg input.
BTW a good check for push-pull is to look at the two output devices. If the signal goes up, does the current through one output device increase and through the other device decrease? Yes? Then it's push-pull.
jd
/Another new issue: Linear Audio Volume 3!
Old 2nd February 2010, 01:32 PM   #7
wahab is offline wahab  Algeria
this is a genuine push pull amp with an output compound pair
with voltage gain...and also vbe variation gain !! that will
lead to great themal instability...
the power devices have no base to emitter resistors that
would allow to get rid of eventual stored charges as these
device can be driven into saturation in this kind of topology,
thus allowing for stored charges to occur...
anyway, a doubtful design...
Old 5th February 2010, 06:36 AM   #8
jd
hi thanks for the replies. BTW which two output devices do u mean?
thank you.
Old 5th February 2010, 07:16 AM   #9
janneman's Avatar
thank you.
Errr... The two devices that drive the output?
jd
Old 6th February 2010, 10:00 PM   #10
thank you.
Q1 and Q2 are the final output devices and arfe the physically largest of the group.
6BQ5 Push-Pull amplifier YFW Tubes / Valves 6 7th June 2007 10:18 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Need Help On Push Pull Amplifier basiliou Solid State 15 11th June 2004 01:20 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.11638 seconds (77.20% PHP - 22.80% MySQL) with 11 queries
