Yesterday I have found Accuphase's discrete jFET Input Operational Amplifier for ultimate sound reproduction (see attachement).
An interesting feature are some parallel connected complementary LTP units behind the input j-FET's. Maybe also suited for I/U converter behind the DAC like PCM1704 or PCM1794 Are there any experience with this circuit topology? To compare with the internal circuit topology from AD797 and OPA827 I have also add as PDF attachement Last edited by tiefbassuebertr; 31st January 2010 at 03:03 PM. |
#2 |
This looks more like the MM input stage of their C-27 phono pre to me, there the input JFETs are just source followers to increase the impedance of the actual amplification stage.
Martin Rupp |
#3 |
Yes it sure looks like their MM stage
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#4 |
A translation of the Japanese in the image:
"MM amplifier is required to achieve low noise while maintaining high input impedance. For this amplifier section, we chose low noise JFET as input device used as buffer (3 paralleled) followed by ultra-low noise Tr in differential push-pull configuration, 6 of them paralleled." Sorry for my English,,,, sigh. Satoru |
| Nature's sound reproduction... | Vikash | Everything Else | 0 | 10th August 2008 12:13 AM |
| discrete jfet input opamp | rubydac | Solid State | 5 | 12th March 2008 04:59 PM |
| Dual Operational Amplifier Question? | lindomar | Class D | 3 | 7th October 2007 08:09 PM |
| need a high voltage operational amplifier! | xiaonan | Chip Amps | 6 | 7th September 2006 04:37 PM |
| sound reproduction and distortion | tech.knockout | Multi-Way | 13 | 16th March 2004 04:40 PM |
| Page generated in 0.07566 seconds (73.71% PHP - 26.29% MySQL) with 11 queries |
