Perform Biasing on B&K ST-140
Old 31st January 2010, 04:17 AM   #1
Falcon is offline Falcon  United States
Default Perform Biasing on B&K ST-140
Hi Forum Members:
I have just replaced the pre-drivers and output drivers on both channels of my B&K ST-140 ( early version with only one pair of output transistors per channel ). I would like to know what is the procedure(s) to check and setup the bias on both channels correctly. Also anything else I need to check and adjust to make sure that everything is fine and within specification? I contact B&K but no response so far. Thanks.
Mike
Old 31st January 2010, 06:50 AM   #2
djk is offline djk
djk's Avatar
Pull one fuse on one channel, adjust the bias to about 125mA (100mA per output plus 25mA for the front end). Repeat for the other channel.
Candidates for the Darwin Award should not read this author.
Old 6th February 2010, 04:59 AM   #3
jonnymyaudio is offline jonnymyaudio  Canada
Default Bias
do you know the steps to bias the newer style with 4 outputs per channel
Old 7th January 2013, 11:55 AM   #4
djk is offline djk
djk's Avatar
Same way, 100mA per output P&N output pair, plus 25mA for the front end
Old 8th January 2013, 05:26 AM   #5
I had a couple problems trying to bias the amp. My readings were all over the map. 1st I was using a cheap multimeter to try and measure ma and 2nd was my 4 100uf 100v caps had a lot of leakage. So I put new caps in and I got a real test meter for measuring ma and now it works like a charm. Thanks djk
Old 4th March 2013, 05:48 PM   #6
tony Ma is offline tony Ma  United States
Here what I got from the factory
Perform Biasing on B&K ST-140Hide this!Advertise here!
b&k st-140 toggle switch replacement thezaman Solid State 4 11th August 2013 04:28 AM
B&k St-140 trouble shooting question nchakos Solid State 26 19th April 2013 02:11 PM
B&K ST-140 Power Supply Schematic Falcon Solid State 1 12th January 2010 06:45 AM
Looking for pn4889 for a B&K st-140 jwv3 Solid State 2 10th February 2004 07:02 PM
Bride of Son of Zen heard shacking up with B&K ST-140... eLarson Pass Labs 8 27th February 2003 12:45 AM
Copyright ©1999-2017 diyAudio
