Old 30th January 2010, 08:54 PM   #1
Default Headphone tap
I am using a nice little realistic SA-102 Amplifier to run headphones. The amplifier has 10W per channel. My headphones are AKG K240. Power was a little low and distorted before they were loud enough so I changed the resistor that are in series to Headphone jack. The originals were 330 Ohm. I installed some 200 Ohm in place. Seems to have improved. Is this the Ideal method? Will I improve quality by going to a lesser resistor. I know very little about the amp (or any amp for that matter). It is my understanding that the amp is class a and has 10v at the rails. It is a surprisingly linear and transparent amp. I would like to see a little more volume out of the headphones. I am using it strictly for headphones.
Old 30th January 2010, 10:26 PM   #2
nigelwright7557's Avatar
Its getting the balance right between enough volume and overloading the headphones and destroying them.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 31st January 2010, 06:05 PM   #3
Mooly's Avatar
200 ohm should be fine. From what I see it's real low powered amp so the voltage swing will be very limited... so on that basis perhaps even 150 ohms may be more suitable... in any case you'll blow your ears off long before the headphones pop so just be sensible and choose something that works well with your phones.
No center tap Help FastEddy Power Supplies 57 19th April 2010 07:01 PM
Would you use a 4 ohm tap with these speakers? Saurav Tubes / Valves 5 26th March 2009 02:42 PM
How to extract a broken tap Vikash Chip Amps 21 22nd March 2007 09:33 PM
New amp from TAP Tekko Chip Amps 12 2nd February 2006 10:24 AM
three tap loudness pot adason Parts 8 26th January 2006 08:53 AM
Page generated in 0.07372 seconds (65.09% PHP - 34.91% MySQL) with 10 queries
