Class B w/o crossover distortion (1975)
Old 23rd October 2010, 03:52 PM   #181
Elvee is online now Elvee  Belgium
Elvee's Avatar
Here are the voltages:
Old 23rd October 2010, 06:17 PM   #182
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Now the circuit works also by me correctly (still by simulation - at least concerning the DC conditions).
Only my first estimate in my previous post causes the simulation error. My second estimate (cathode of D2 seems to be also wrong connected) wasn't right.
File Type: pdf Circl.Elvee Visch-II Frequency Response.pdf (5.0 KB, 68 views)
File Type: pdf Circl.Elvee Visch-II Clipping Behaviour.pdf (8.7 KB, 77 views)
Old 2nd April 2011, 05:08 PM   #183
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Time to wake this thread up again.
Here's another modification to the Visch topology - a buffer that combines the reactive bridge from the Quad current-dumping circuit with a simplified Visch darlington output stage, driven by an ultra-low distortion opamp. It's biased in Class-AB with about 25 mA quiescent current in the output stage. There's still a lot of optimization to be done, but the initial results look very promising. At 10V output amplitude into 8 ohms, THD20 is below -120 dB, with H2 dominating.
It's probably most suitable for driving low-impedance headphones, but it could also be used as a line-level buffer. All the devices (except the opamp) are commodity jelly-beans types - the output darlingtons could probably be substituted by TIP122s with nominal impact on sonics.
Old 2nd April 2011, 07:49 PM   #184
very interesting idea. Unfortunately I don't understand, from where flows the output current through RL.
Old 3rd April 2011, 01:00 AM   #185
artu is offline artu  Chile
artu's Avatar
This is a Feed Forward error correction amp isn't it?
Old 3rd April 2011, 12:01 PM   #186
It's missing the junctions where the wires meet at 90 degrees - an LTSpice .wmf problem. Just assume that all wire-crossings have a junction, except where there is a U-shaped dog-leg at the crossing.
The load is driven by U2, U3 (darlingtons) through L1 (part of the reactive bridge C1-R3-L1-R4). There's a small feed-forward correction (a few mA) from the opamp through R4. It's possible to decrease distortion a bit by decreasing R4 (and rebalancing the bridge), but at some point the odd-harmonic character of the LME49860 output stage will start dominating.
Old 3rd April 2011, 06:58 PM   #187
Thank you for your explanations.
Old 4th April 2011, 06:12 AM   #188
kenpeter is offline kenpeter  United States
Elvee, I don't mean to nitpick but your VischB crosses above 1A.
And thats just the collectors of the 3055's. Haven't even added
driver currents into that figure yet...
Old 4th April 2011, 06:31 AM   #189
Now, thats more like B... 100mA crossing for the big transistors.
Late discovery: With Schottkys as shown, R1 R2 can be Muntz'd.
Old 4th April 2011, 07:50 AM   #190
Elvee's Avatar
It does, and it doesn't:
It is one of the difficulties with this circuit, the dynamic stability of the quiescent current.
The first pic shows the circuit operating at a very low power.
The Iq is a nice ~30mA. Note however that the positive and negative crossings occur at a different level. This is caused by the time-constant of the Visch "memory cap". Yet, the frequency is not very low.
The second picture is made at 25V^ output; now the crossing occurs at 1.8A.
This could be seen as a "feature": dynamic biasing following the music level.
But in addition to the increased dissipation, it also has a major drawback: it takes time to settle to the new condition: the third pic is taken under the same conditions, but at the beginning, when the circuit didn't yet have time to adapt.
There is a severe clipping for a number of ms.
When the circuit is near idle condition, it spends most of the time servoing the Iq.
But at higher current levels, the waveform on D1 becomes trapezoidal, and the servo action occurs only in the linear mode, during the transitions.
But if, on the other hand the circuit is not perfectly balanced, the duty cycle of the trapeze (almost a square wave) will dominate the average voltage and cause a shift in the bias.
I have made a number of real prototypes, and the problem seems almost impossible to solve satisfactorily.
Class B w/o crossover distortion (1975)Hide this!Advertise here!
low crossover-distortion class AB output stage topologies capslock Solid State 72 10th May 2013 07:48 PM
Exactly titles of old transistor data books from NEC, SONY and Fujitsu (1975 - 1985) tiefbassuebertr Solid State 5 12th December 2011 05:31 PM
Crossover distortion - be gone! Circlotron Solid State 4 24th August 2009 12:09 PM
Crossover distortion lumanauw Solid State 100 14th January 2005 12:58 AM
Crossover Distortion? Killjoy99 Multi-Way 8 30th March 2004 05:10 AM
