Class B w/o crossover distortion (1975) - Page 2 - diyAudio
Old 30th January 2010, 09:40 PM   #11
hahfran is offline hahfran  Germany
Ah yes indeed that explains how no crossover distortion appears even with class B setting of the power BJTs. It appears the same design idea is realized in the old QUAD 303? But why the bootstrap? And indeed the emitter of the current source is forced to -34.4 volts same as the base. If I hadn't built in 1976 I were sure it cannot work but since I have I see it works...
Old 30th January 2010, 09:49 PM   #12
grufti is offline grufti  United States
grufti's Avatar
There is a Dutch company in the audio business called Hawk Audio that traces its roots back to Nico Visch. They mention him in their "About" page.
Hawk Audio Design Philosophy
Old 30th January 2010, 09:57 PM   #13
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Those hairs 'fire' electrons, let's say a kind of digital '1' signals, into the brain.
The Devil is not so terrible as his math model is!
Old 30th January 2010, 10:04 PM   #14
AKSA is offline AKSA  Australia
Yes, I'd seen that some time ago, Hawk Audio is most progressive.......
The purpose of the bootstrap around the 250uF cap is to maintain a near constant current through T1, T4 and T7. Upon the constancy of this current depends the consistent 1.3 volts drop between input and output, and hence the linearity. The bootstrap cap strongly defines the voltage at the collectors of T4 and T7, which would prevent collector of T7 going too low as it draws current from T5 on negative swings, otherwise cutting out the transistor.
The disadvantage of this circuit is the additional negative supply for the emitter of T7, which sets the quiescent. Manufacturers hate additional supplies; they really louse up the costs.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 30th January 2010, 10:24 PM   #15
Bigun is offline Bigun  Canada
Bigun's Avatar
I love this circuit - it offers some intrigue that could keep me busy in Spice for weeks, if not longer. Hey, maybe I should build it, I have some of those old output devices.
I guess modern Class AB is now so darn good there's no call for this type of thing anymore. But I like the golden oldies... there really is a lot of stuff out there in the archives.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 30th January 2010, 11:53 PM   #16
Gareth,
You should acquire a copy of 'The V12 Engine', by Karl Ludwigsen. There are a LOT of golden oldies there, and they are much more interesting than the mass produced fours and V6s we see today......
Hugh
www.aksaonline.com
Old 31st January 2010, 12:40 AM   #17
kipman725's Avatar
Send a message via MSN to kipman725
I think this idea is actually very common in commercial amplifiers, I have a 1980's era amplifier that uses an amplifier chip biased into class a using a ccs as the error amplifier with very good results.
Old 31st January 2010, 03:36 AM   #18
Bigun's Avatar
Originally Posted by AKSA View Post
Gareth,
Hugh
It sounds very interesting. My only experience of a V12 was riding in a friends Jaguar XJS many many years ago. What an absolutely stunning engine. It was so darn smooth I really would have believed it was something other than an internal combustion engine. And boy did it move.
Old 31st January 2010, 05:58 AM   #19
Gareth,
The Visch circuit can be improved with a Baxandall diode, cap and resistor all in parallel between emitter of the pnp driver and output rail; distortion is reduced from 0.0077% to about 0.005% according to the sim at 1KHz +20dBU output (14.5Vp). But you'd have to build it to find out how it sounds, of course.
The Jag V12 was a good motor, but there are better. Cooling was a major problem, particularly in Oz.
Hugh
www.aksaonline.com
Old 31st January 2010, 09:16 AM   #20
Hugh
I had solved that problem with a voltage doubling extra rectifier 2 diodes 2 caps. Voltage regulation improved the sound quality.
The amp was at first used as lead vocals amp in our high school rock band.
When I was university student the amp was always lended to someone...
after that it had driven a low frequency horn speaker...and it still works today no failure at all!
Clever rugged design indeed. The secret of its musical sound could be the spectrum of the harmonics.
low crossover-distortion class AB output stage topologies capslock Solid State 72 10th May 2013 07:48 PM
Exactly titles of old transistor data books from NEC, SONY and Fujitsu (1975 - 1985) tiefbassuebertr Solid State 5 12th December 2011 05:31 PM
Crossover distortion - be gone! Circlotron Solid State 4 24th August 2009 12:09 PM
Crossover distortion lumanauw Solid State 100 14th January 2005 12:58 AM
Crossover Distortion? Killjoy99 Multi-Way 8 30th March 2004 05:10 AM
Copyright 1999-2017 diyAudio
