#91 | |
I think however this is academical because if U(t)=a*sin(2pift) then ic=a*cos(2pift)*C if R3=0 ( then it isn't bootstrapping) BUT no acoustical instrument starts up with full amplitude a! Rather the sonic character of an acoustical instrument is determined by the attack -sustain- release envelope and the dynamically changing harmonics spectrum in this time. The attack time of for ex. a violin is about 10 ms same for a flute for large organ pipes its already seconds. So the case you brought up happens only in very rare cases, especially in electronic instruments. In practice this kind of distortion does not apply except if you prefer to listen to sine bursts 5 on 50 off. |
#92 | |||
However, I see at least two examples of such instruments: -Percussion instruments, drums, cymbals, bells... -Pinched cords instruments, typically guitar Anyway my opinion is, that an amplifier has to be technically flawless (blameless?) before proceeding any further Quote:
In my opinion, cutting corners from the start of a design is not a good idea. If the task really seems impossible, you can begin to think about "simplifications", but it is only a last resort option (for me anyway). |
#93 |
I refer to the Vish schematic. Every bootstrap cap has to deliver current ...
The bootstrap cap must supply the 15 mA when the current source is off at negative swings and is recharged by the current source. With pencil-and-paper methods I cannot confirm the effect shown in the simulation. I will attempt to find out "who is wrong". |
#94 |
The capacitor in the Visch circuit is not a bootstrap. It is an analog memory element, holding the actual Iq setting.
The charge and discharge paths are entirely non-linear, and the reasoning pertaining to a bootstrap capacitor cannot be applied. The maximum negative swing is ~30.5V, and this shows that the presence of the capacitor does nothing to improve that aspect: see the clipping example. The circuit needs about 500ms to reach its full amplitude, and at that time, the Iq amounts to ~2.2A. |
#95 |
Well a bootstrap capacitor is supposed an analog memory because it is assumed that
q=CV= const and therefore the voltage swing is transferred in full. However every bootstrap cap must supply current and must be recharged. Therefore at low enough frequency the assumption does not hold. With discharge q decreases and V=q/C drops. This is why there must be something wrong with the sim. Initially the C is charged and if dq/dt=i=15mA leads to a V drop of dV that makes the clipping then this must be always so there is no reason for a "recovery". The "time consant" of 500 ms cannot follow from iconst*C You may do a sim of i(R3) Last edited by hahfran; 11th February 2010 at 12:18 PM. |
#96 |
I think I(R3) is only moderately interesting, because the voltage across R3 is constrained by the Vbe of Q1.
More interesting is the current in R7. Q7, D1 and Q2 act as a sort of PWM modulator, sharing the 15mA between Q7 and Q2. The process operates in a closed loop and takes time to reach an equilibrium, and only part of this current is available to charge the capacitor. |
#97 | |
In the amp I made back in 1976 or so D1 is actually a big power germanium transistor C/B shortened ( as it seems I don't know the configuration of the 3 pins ). I still think the problem is in the sim right now its way too cold down in the basement ( for me not for the amp) to measure the amp but as far as I recall no effect like that has been observed. |
#98 |
Substituting a schottky for D1 doesnt change the behaviour.
Here is the voltage across the cap: goes from 1.69V when idling to 4.4V at full power. |
#99 |
Hum...when biased properly ( DC offset 1.3 V SINE) the voltage across the cap should be 15 volts with no ac signal applied.
#100 |
If the cap had 15V, this would mean that all the bias current goes into the string of predriver transistors, with nothing left for Q2.
It would be a hard-switching class B. Last edited by Elvee; 11th February 2010 at 04:59 PM. |
| low crossover-distortion class AB output stage topologies | capslock | Solid State | 72 | 10th May 2013 07:48 PM |
| Exactly titles of old transistor data books from NEC, SONY and Fujitsu (1975 - 1985) | tiefbassuebertr | Solid State | 5 | 12th December 2011 05:31 PM |
| Crossover distortion - be gone! | Circlotron | Solid State | 4 | 24th August 2009 12:09 PM |
| Crossover distortion | lumanauw | Solid State | 100 | 14th January 2005 12:58 AM |
| Crossover Distortion? | Killjoy99 | Multi-Way | 8 | 30th March 2004 05:10 AM |
