Old 29th January 2010, 09:52 PM   #1
Default Bryston 4B ST Clone Started
Bryston amps are legendary, and many people here have toyed with the idea of building one. Well, I've started a 4B ST clone. So far the PCB's have been designed, manufactured and I have most of the components for the main amp boards installed. I've been pondering how exactly to set the bias on the amplifier though. I've not had any luck finding a service manual or other document with this information. Any ideas?
(will post pics soon)
Old 4th February 2010, 09:39 AM   #2
I am looking for waiting your project.
Old 4th February 2010, 09:49 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
The Brystons are optimum biased ClassB amps, no? So you would need a distortion analyzer to set the bias to minimum distortion.
Soundcard with decent software will do also.
Have fun, Hannes
Old 5th February 2010, 01:32 PM   #4
Default Photos of the amp boards
Here are the amp boards, I have all the passives installed minus some jumpers and output inductors. The output transistors in the one image are just to show spacing and that these will go through the heatsink and solder directly into the pcb. The boards will also mount directly onto the heatsink. Signal paths are short and compact. Metal film 1% 3/4W resistors for the most part, audio critical caps are poly film, boards are double sided gold plated. Schematics can be found on the Bryston website. Next is to clean these up, mount them on heatsinks and get a power supply running to start testing. Wish me luck!
Old 5th February 2010, 01:55 PM   #5
Audio Junkie
Zero Cool's Avatar
I will be very curious to see how these come out. The 4B for some reason really has good bass control. I couldn't believe the difference, it was like adding another entire octave to the bottom end of my speakers simply by swapping in an old 4B, but the top end was too harsh for my liking. But that was an old 4B I was playing with too. not the ST version.
Zc
Old 5th February 2010, 03:20 PM   #6
Bigun is offline Bigun  Canada
Bigun's Avatar
I have a Bryston integrated, essentially the 2B. It's no 4B but I would echo that comment on the bass and the high end of the frequency range, although I wouldn't describe the trebles as harsh I would say I find listener fatigue after a few hours.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th February 2010, 05:16 PM   #7
taj is offline taj
taj's Avatar
So, is this just "show and tell", or are you going to divulge your PCB layouts and plans for the project? Will others be able to build this based on the work you're doing? What's your plan?
What chassis are you designing this for? The cutouts in the PCB have an obvious purpose, but I can't guess what that might be.
..Todd
Old 5th February 2010, 05:30 PM   #8
Not entirely sure yet. Just wanted to get some feedback on how to set the bias on this properly. Depends on how much interest there is and how well it works out. I'll document as I go and put together a build-through pdf,
I'll be building the chassis from scratch (that's the current plan plan anyway)
Old 5th February 2010, 08:21 PM   #9
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
How about posting the schematic you're working from?
AJ
Old 5th February 2010, 10:10 PM   #10
AVWERK is offline AVWERK  United States
What was the reason you designed the TO3 closer to center rather than at the edge where it would be easier to sandwich a heat sink assembly together?
David
FS: Bryston 4B NRB akunec Swap Meet 0 12th December 2006 11:18 PM
Bryston 3B/4B-SST clone? taj Group Buys 3 9th December 2006 07:46 PM
idle current for bryston 4B Danielll Solid State 2 3rd October 2005 05:25 PM
Off Topic but need help on a Bryston 4B ST Amp zhangtony Solid State 3 9th June 2004 09:06 AM
Looking for a Bryston 4B ST clone Phil O.son Solid State 5 6th November 2002 08:36 AM
Page generated in 0.18889 seconds (52.30% PHP - 47.70% MySQL) with 11 queries
