what would cause an amp to hum is it to much current,even with no music playing?
#2 |
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
If the wiring scheme is ok, its usually the transformer being too close to the amp-boards.
Most DIYers build however big enclosures, so that seems to happen only rarely. If it's the wiring scheme, you need to give more details Have fun, Hannes PS: Sakis, did you really had one occasion where you could hear rectifier noise from the speakers? I'm just curious as in my experience everything else is so much bigger. |
#4 |
Yes i did ....also problems like that are by far more obvious when you have to do with preamps .... so amplifiers are the same thing only gain and signal levels are nto the same
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr Last edited by sakis; 29th January 2010 at 11:25 AM. |
#5 |
Is it hum ?... 50/60 hz fundamental which is a very pure LF tone, or a much harsher 100/120 hz "buzz" with harmonics ?
That's a vital clue as to what the problem is. |
#6 |
is the hum a mechanical hum from the amplifier case, or an electrical signal hum coming from the speaker cone?
regards Andrew T. |
| where should I put the tweeters? | PeteMcK | Multi-Way | 7 | 27th July 2007 04:33 AM |
| Looking for someone to put a crossover together for me | Xristo | Multi-Way | 11 | 3rd August 2005 08:39 AM |
| Out Put Transistors | RaidersGuy | Solid State | 0 | 12th February 2005 07:47 PM |
| I've put loadlines aside for a while... | Mikael Abdellah | Tubes / Valves | 22 | 5th May 2003 07:17 PM |
| Page generated in 0.08721 seconds (73.35% PHP - 26.65% MySQL) with 10 queries |
