LME49990 Audio Op-Amp - better than AD797?
Old 31st May 2011, 08:38 AM   #31
Sergelisses is offline Sergelisses  France
Yes i know but i have never ordered in USA .
I don't know if it's possible for just two AOP ?
Serge
Old 31st May 2011, 11:18 AM   #32
parb is offline parb  United States
Why not just use farnell in france. they seem to stock the part (there is some blurb about business customers but surely you can find a business license?)
Old 31st May 2011, 11:25 AM   #33
jonclancy is offline jonclancy  United Kingdom
It's that one off USA stock charge that makes it uneconomic in the UK. However, a bulk order would mitigate this...
John Linsley Hood Ripple Eater GB Part One made 729 for Cancer Research UK. Thanks for your support!!!
Old 31st May 2011, 11:58 AM   #34
There is a minimum order .
I don't know why on the NS site ,i have asked samples ...no asnwer .
With TI and LT no problem very fast !!!!
Serge
Old 6th December 2012, 04:06 AM   #35
rodselectronics is offline rodselectronics  Australia
Smile LME49990MA
I have seen these for sale on element14.com
I have implemented these on a WM8741 mono dac as a summing buffer and it was very suited in this application.
Sound wise was very extended BASS! Clear mid range with a sweet top end.
I have tried a few op amps like the famous AD825, and the LME49990 was more smoother with a more solid low end.
Rod.
Old 8th January 2013, 12:21 PM   #36
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Rod.
THank you for this advices.
Old 9th January 2013, 07:48 AM   #37
Default LME49990MA
Is the AD797 better than the LME4990?
Well I have no AD797 to try the A/B Test.
A look at both data sheets suggest a close match as specs are concerned.
When you compare a high spec op-amps is that the power supply and the quality of surrounding components plus the particular application will influence the sound quality.
The best way is to compare the op-amps in your application.
Ensure that you use top quality components and power supply rails.
Cheers.
Old 12th October 2013, 08:15 PM   #38
afshindiy is offline afshindiy  Iran
afshindiy's Avatar
Hi
I love LME There. Single voltage +5 V when the drive there? To use the output D/A.
Tanks .
LME49990 Audio Op-Amp - better than AD797?Hide this!Advertise here!
Need help selecting and LOCATING the best op-amp for guitar audio jeghers Instruments and Amps 4 2nd January 2009 04:46 AM
Best Op-Amp for audio (guitar) LesPaulStandard Instruments and Amps 35 15th November 2008 07:53 PM
AD797 Op Amp - Nightingale PTS01 eleakist Parts 7 15th July 2007 01:56 AM
Where can I get an AD797 Op-Amp? xanduy Swap Meet 4 29th March 2004 08:06 AM
AD797 op amp in active xover 5th element Solid State 3 1st March 2003 03:32 PM
