LME49990 Audio Op-Amp - better than AD797?
Old 27th November 2010, 05:51 PM   #21
twest820 is offline twest820
Originally Posted by abraxalito View Post
methinks someone didn't factor in the 101 factor of their distortion magnifier...
I just noticed that as well; it's fixed in version 1.02 of the datasheet released in back in late March (though some of the other issues still aren't). Overall it looks like an interesting part for DC servos--my shortlist there is the TL071, LME49880, and ADA4637. The 49880 fills the gap between the TL071 and ADA4637 rather nicely, though the TL071's plenty for the standard servo implementation where all the servo does is integrate.
Old 29th November 2010, 03:07 AM   #22
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
For servo duty, there are some newer TI offerings which look worthy. That is assuming that lowish noise and bias currents are desirable (they would be to me if I were seeking out a servo amp). OPAX141, OPAX376 and OPAX209. The latter is bipolar but has lower noise than any JFET I've seen coupled with commendably low input bias current for a bipolar. They're all considerably lower cost than the AD part you've mentioned though clearly dearer than the humble TL071.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 29th November 2010, 01:55 PM   #23
Yeah, nice parts, particularly with the SOT-23 availability in the single channel versions. Too bad the OPAx209's a RRIO and hence likely requires it's own set of rails in typical audio designs; particularly good specs there. For 15V rails the LMC6801 might be an interesting alternative.
So far I've found the TL071's quiet and low bias enough as an integrator. What usually pushes me away from it's need for speed and linearity characteristics more like an audio op amp. Haven't found a precision op amp with both those properties, though I haven't looked particularly hard.
Old 30th November 2010, 10:14 AM   #24
Calvin is offline Calvin  Germany
Calvin's Avatar
whats RRIO?? The OPAx209 are specced for single or dual supplies of up to 36V/2x18V and the pin -layout of the MSOP and SOP-types is common style.
Why should they require a own set of supplies??
Look really interesting for Phono-stages
jauu
Calvin
Old 30th November 2010, 10:30 AM   #25
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
RRIO = Rail-to-rail input and output.
Old 30th November 2010, 01:36 PM   #26
My bad; OPAx376's the RRIO.
Old 30th November 2010, 02:15 PM   #27
abraxalito's Avatar
The OPAx376 is CMOS, limited to 5.5V supply. The thing to watch with these low noise CMOS amps with rail-rail inputs is that the full CM input voltage range isn't usable for audio (i.e. with low distortion) so they ain't really RRI. This TI part is better than most, it can go to about 1V below the positive rail before distorting. One of Maxim's similar parts (MAX4475) doesn't do half as well though its noise is even better. The headline low distortion figures (which, let's face it, are pretty impressive) are only achieved when keeping within this CM input voltage limit.
Old 29th March 2011, 04:56 PM   #28
qusp is offline qusp  Australia
qusp's Avatar
lme49990 = winner by a mile and ad797 has been my favorite chip for years. i'm yet to try it out in any regulator designs, 797 was also incredibly versatile; but i surely will. so far i have used it in simple iv and in opc's 'the wire' headphone amp with balanced input and lme49610 in the se output. this combo is killer, best sound i have ever heard from chips and owens name for his amp is entirely apt
Old 30th May 2011, 07:28 PM   #29
Sergelisses is offline Sergelisses  France
Hello
Where to buy the LME49990
I don't find it on Ebay !!
Serge
Old 30th May 2011, 07:45 PM   #30
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by Sergelisses View Post
Hello
Serge
Digikey, Avnet, Future Electronics, Arrow Electronics all carry the part.
LME49990 Audio Op-Amp - better than AD797?Hide this!Advertise here!
Need help selecting and LOCATING the best op-amp for guitar audio jeghers Instruments and Amps 4 2nd January 2009 04:46 AM
Best Op-Amp for audio (guitar) LesPaulStandard Instruments and Amps 35 15th November 2008 07:53 PM
AD797 Op Amp - Nightingale PTS01 eleakist Parts 7 15th July 2007 01:56 AM
Where can I get an AD797 Op-Amp? xanduy Swap Meet 4 29th March 2004 08:06 AM
AD797 op amp in active xover 5th element Solid State 3 1st March 2003 03:32 PM
Copyright ©1999-2017 diyAudio
