Le Monstre Fet connection! - diyAudio
Old 3rd June 2003, 10:14 PM   #1
Audiofanatic's Avatar
Default Le Monstre Fet connection!
Hi Monstre DIYers,
I want to build two Le Monstre Monoblock's but don't know how to connect the Fet's at the input.
Are the drains connected to the 100 ohm pot or the source?
Or the source from the upper and the Drain of the lower fet or the other way around?
Thanks in advance!
Audiofanatic
P.S. look at the arrows and the dots!
Be nice to animals.
Old 3rd June 2003, 10:42 PM   #2
diyAudio Senior Member
fdegrove's Avatar
People like Ralph and Jam might be able to help you out....
I'll need to browse my books if they fail to respond.
Frank
Old 3rd June 2003, 10:56 PM   #3
rickpt is offline rickpt  Portugal
rickpt's Avatar
Hi
You can reverse the source and the drain without any problem; just make sure the gate is in the right place
http://www.rason.org/Projects/jfetamp/jfetamp.htm
Old 3rd June 2003, 11:28 PM   #4
Default J-fets
2SK170 Fet's drain connect to 1K at + power supply, 2SJ drain to 1K at - power supply.
2sk170 - n channel j-fet. In "normal" mode ( called saturation ) drain is positive respect to gate, and gate is negative respect to source.
Or, drain is positive respect to gate, source is positive respect to gate but less than drain is. Result drain is positive respect to source.
2sj74 p-channel drain is negative vs gate, source is negative vs gate, drain is negative vs source.
Old 4th June 2003, 01:46 AM   #5
Tube_Dude's Avatar
Default Re: Le Monstre Fet connection!
The sources must be connect to the 100 Ohms pot!!!
Cheers
Jorge
Old 4th June 2003, 02:11 AM   #6
jam is online now jam  United States
jam's Avatar
The sources are connected to the 100ohm pot, like the Tube Dude says, be shure the color or rank of both fets are the same. Check for correct bias on the output stage.
Good luck!
Jam
Old 4th June 2003, 02:14 AM   #7
jam's Avatar
Talking Long live Silicon!
Frank,
I see that you have been trolling the solid state forums again.....
Jam
Old 4th June 2003, 02:21 AM   #8
jam's Avatar
Forgot the pic....
Old 4th June 2003, 09:08 AM   #9
Hi DIYers,
Thank you very much for your help.
I didn't expect so much reaction on this thread.
I'm realy thankfull to you all! I'll report a.s.a.p. to you guys when my two Le Monstre's are ready.
To Frank, ik vind het heel attent van je dat je bereid bent/was mij hiermee te helpen. Dankje wel!
Frendly greetings,
Audiofanatic
P.S. If I succeed in making new PCB's I'll post it eventually on this thread.
Be nice to animals.
Old 4th June 2003, 03:42 PM   #10
fdegrove's Avatar
Default Re: Long live Silicon!
Hi Jam,
Long live Silicon Valley?
Trolling? Qui? Moi?
You know that when I see something like Kaneda, Le Monstre or Hiraga I just have to subscribe to the thread...if only to prevent you guys from making mistakes.
Hi Audiofanatic,
Thank you, I actually didn't do anything...yet.
Frank
Hiraga 30W vs. Le Monstre JohanH Solid State 103 14th April 2008 10:27 PM
Le Monstre MOSFET argo Solid State 16 4th September 2004 07:15 PM
Le Monstre MikeW Solid State 22 15th May 2004 09:26 AM
Copyright ©1999-2017 diyAudio
