Old 26th January 2010, 01:55 PM   #1
Mark245 is offline Mark245  United States
Default First power up testing procedure
Hey everyone,
I have breadboarded a 20 watt amplifier. I want to make sure it is going to work right before I go to the trouble of making a pc board. The first time I plugged it up, the output stage blew. I replaced the output transistors and fixed the bad connection that I had. Now, when I adjust the pot on Qbias, I get a Vce of 0 volts and 1.3mV across R35 and R36 no matter how I adjust the pot. I read that you want 1.28v Vce on Qbias and 8mV across R35 and R36. Does the load need to be connected to set the bias current? I have checked all transistors and they are Ok. I have also verified all connections.
The circuit schematic is attached.
Someone mentioned using AM oscillator detector. What is this used for, to detect if the amp is oscillating? I have an O'scpoe and function generator. What is the correct procedure for testing if the amp works?
This is really my first time testing an amplifier with considerable complexity so I am not really sure as to what steps I need to follow. The schematic is attached. Any help will be greatly appreciated.
Mark
Old 26th January 2010, 02:07 PM   #2
AndrewT is online now AndrewT  Scotland
q7 is passing ~6mA.
The Vbe multiplier resistors are too low value for this value of VAS current.
The combination of C3 and R19 is too low, F-3dB ~11MHz
The ratio of C8+12 : C2 is wrong. This one is not the problem.
Use a mains light bulb tester to power up all your new or modified projects.
regards Andrew T.
Old 26th January 2010, 09:07 PM   #3
nigelwright7557's Avatar
Could be Q7 died with the output transistors ?
I set bias without speaker connected in case DC offset gives false readings.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Power amps burn-in procedure. beppe61 Solid State 92 20th August 2010 10:35 AM
Power Tranistor Testing argonrepublic Chip Amps 4 14th January 2006 08:39 AM
Testing a power amp AndrewT Solid State 8 13th August 2005 03:43 PM
Procedure for sorting power transistor ? Miles Teg Pass Labs 3 12th November 2001 11:09 PM
Page generated in 0.08351 seconds (70.30% PHP - 29.70% MySQL) with 11 queries
