Hi!
I have an old Nikko Alpha II power amp which protection cuts off after about 1 minute..Then I turn it off and wait for 10 minutes and try again, and the same thing happens, only this time it happens after 30 seconds..And so on.. The amp acts normal until it cuts off, and all the speaker outputs work fine.. What can it be? Thanks, Tomzern (newbie from norway) |
#2 |
This must be this power amp:
Nikko Alpha II Power Amp - Audiokarma.org Photo Gallery either you have DC at the output after a minute and thus protection cuts off, or some faulty electrolytic caps arround the protection circuit itself - maybe Toshiba's TA7317 - TA7317P Datasheet pdf - PROTECTION CIRCUIT FOR OCL POWER AMPLIFIER AND SPEAKER - TOSHIBA are the cause. Please order your copy of service manual about Schaltpläne und Bedienungsanleitungen: Schaltungsdienst Lange oHG info@schaltungsdienst.de Schaltungsdienst Lange oHG Zehrensdorfer Str. 11 12277 Berlin-Marienfelde Tel.: ++49 (0) 30 / 723 81-3 Fax: ++49 (0) 30 / 723 81-500 All electrolytic caps - at least arround so called "hot spots" on the PCB - must be replace. Rifa, FTcap and EPCOS are good brands for replace, even by the small size devices. Last edited by tiefbassuebertr; 26th January 2010 at 01:35 PM. |
#3 |
That's the one yes
I'm delivering the amp to a local AV-technician, so that he can find out exactly which component(s) that causes the problem. I'm hoping it's no big deal, but we'll see Thank you for your response! -Tomzern |
| Who knows the Nikko Alpha II ? | ginetto61 | Solid State | 4 | 20th October 2009 04:45 PM |
| Nikko Alpha Ii Schematic | sakis | Solid State | 6 | 11th June 2009 10:42 AM |
| Nikko Alpha 220 | GEirin | Solid State | 4 | 17th April 2008 08:34 PM |
| Nikko Alpha II amp troubleshooting | livetoski | Solid State | 58 | 22nd February 2007 05:11 PM |
| Nikko Alpha 130 | ecliptica | Parts | 1 | 29th January 2004 10:16 PM |
| Page generated in 0.09907 seconds (74.59% PHP - 25.41% MySQL) with 11 queries |
