#31 |
Ask yourself why VT1 ,VT2, and VT3 all have working points dependant upon
Gm curve, rather than linear Mu? This design wastes 3 SITs by disabling their best secret weapon, dumbing them down to ordinary FETs. |
#32 |
#33 | |
I would be extremely interested in your listening reports, about more perfect schematics. There are many of them, at the tubecad pages. In all cases, when I loved some schematics theoretically, no cap in the signal chain etc., I did not manage to get a sound. Main tricks relate to noise level, using of shunt PS concept, parts selection, design induced EMI, slew-rate, etc., i.e. to aspects not directly linked with linearity. In spite that this schematics looks as very trivial, it can not be approached sound-wise by varios other preamps laying around. Last edited by VladimirK; 27th August 2011 at 07:04 PM. |
#34 |
Do you have triode model for the 2sk79?
I have no SITs, only a box of 6DJ8 if I had to prove something... |
#35 |
Kenpeter, see if this will help you.
Don't ask me about it.
The truth is out there. Who can handle the truth? |
#36 |
Faking Mu aint all that hard either.
Granted, some cropping was involved. Looks less convincing outside the box. Last edited by kenpeter; 27th August 2011 at 08:11 PM. |
#37 |
This type of output curves (artificial triode) is the general property of
all transconductance amplifiers (high output imp.) with the voltage FB. Vbe multiplier is one example. Opamps with the voltage FB will also have this type of output curves. Sure, one transistor is the second shortest FB path (loop), (after "emitter" follower).
| SIT Power Amplifier??? | mad_z | Solid State | 8 | 26th January 2009 08:31 PM |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| New SIT - old problem | StevenOH | Parts | 2 | 13th June 2008 10:46 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| HELP! Receiver to deep to sit on shallower DVD player | xRAzORx | Everything Else | 2 | 14th June 2006 10:16 PM |
