No Ground = Great Sound
Closed Thread
Old 22nd January 2010, 01:02 PM   #1
ronzeman is offline ronzeman  United States
ronzeman's Avatar
Default No Ground = Great Sound
I recently upgraded from an old Hafler (DH110) preamp to a new Linn. The new pre uses a three prong grounded AC plug...the Hafler was a two prong ungrounded unit. The new pre has a very faint humm ( down 70db? ) when plugged into a grounded power strip. When I Ungrounded the preamp, the Linn was dead quiet ! I mean it was like it was not even turned on ....SUPER quiet.
Is there any risk running a preamp "ungrounded" ? My Halfer was happy being ungrounded for 20 years. I know grounded equipment has less risk of shock hazzard, but other than that is there any other consideration?
Old 22nd January 2010, 01:12 PM   #2
StigErik is offline StigErik  Norway
StigErik's Avatar
There's a reason that Ground Lift Adapters exist.... to avoid ground loops and hum.
The only consideration is safety (risk of electric shock). 110 V like you have in the US is not really that dangerous anyway....
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 22nd January 2010, 01:40 PM   #3
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Use a back to back diode safety floating scheme. What you do is you employ two 5A diodes in parallel with their strap marked ends joined in opposite. You put those at the grounding point you lifted the cable from, and you attach that grounding cable on the new end. Now you got a ground lift but in case of a problem, current can run in the safety ground since the diodes are going to conduct in any 0.7V and over incident. Else, if any chassis develops a potential due to a fault in any system, the house safety trip relay that senses ground will know nothing about it and its against any safety rule. Be generally cautious.
Old 22nd January 2010, 02:10 PM   #4
SQLGuy is offline SQLGuy  United States
Does this actually work? Have you tried it?
By the way, the GFI/GFCI should still trip even if ground is isolated at an end point. Yes, it stands for Ground Fault Interrupter, but it actually trips when current out through hot doesn't match current returned through neutral. Ground doesn't enter into it.
A common source of ground loops I've seen is the difference between the ground of AC power and the ground provided by a cable TV cable. These come together in AV systems. One solution for this is to get a 75 Ohm isolation transformer, or make one by using a 75-300 Ohm balun connected to a 300-75 Ohm F-Plug adaptor. Adding this in-line with the incoming cable separates the ground but couples the signal.
Old 22nd January 2010, 02:21 PM   #5
wg_ski is offline wg_ski  United States
Yes, it does work. I install them in every pro amp I build. But use a heavy duty full wave bridge. Strap + to -, then use the AC as the loop breaker. A high current bridge will handle very large fault currents without failing open, and will provide two diode drops instead of only one. Voltage rating does not matter so a 50V part that you can't use for an amp power supply will work.
Old 22nd January 2010, 02:22 PM   #6
Salas's Avatar
Yes I have it in some of my DIY builds. It works. Its fairly known from some power amps.
GFI/GFCI works as other schemes globally? Is it totally safe without ground?
Old 22nd January 2010, 02:22 PM   #7
ronzeman's Avatar
Default More Info
Yes I do have a SAT TV ( sound ) in the loop so to speak. But with EVERYTHING ( 3 power amps; 1 electronic crossover; 1 CD player) all turned OFF the results are the same.
It just seems so much easier to run the preamp ungrounded and have black hole silence like it was with my ungrounded Hafler for the past eons. I'll keep reading your posts on safety and possible fixes. THANKS !
Old 22nd January 2010, 02:25 PM   #8
Salas's Avatar
Yes its good. I use lighter 5A diodes or bridges in line level equipment.
Old 22nd January 2010, 02:37 PM   #9
Yes. For example, the ABB GFCI modules (in the breaker box) I installed when upgrading the electrical supply in my apartment don't connect to ground. The main one was three phases hot plus neutral. The bathroom one was one phase hot and one neutral. Further, in that apartment, in Belgium, we actually didn't have neutral; all 220V power was two hot phases. So, in that case, the correct wiring was to jumper the neutral on the main GFCI to one of the hot phases, while the bathroom GFCI gets hot/hot.
I added ground to all the outlets (original wiring was from 1966 and didn't have ground), but ground still had nothing to do with GFCI.
The basic idea is that if you have a device that's leaking current to some non-standard return path, the GFCI will trip. E.g., a hair dryer dropped in the bathtub, where current will be flowing from hot to the ground of the tub/plumbing, rather than coming back through neutral.
Old 22nd January 2010, 02:43 PM   #10
On Hiatus
SY's Avatar
Other than potential death to you or some innocent person? No, not really.
NEVER NEVER NEVER operate equipment with the safety ground disconnected. NEVER!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Closed Thread
No Ground = Great SoundHide this!Advertise here!
Orions sound great because dipole? sendler Multi-Way 921 16th December 2008 09:19 PM
Will it ruin the great sound I have? Marsh Subwoofers 27 27th June 2007 07:04 PM
FS Gainclone Great Chassis, Potted toroidal, great sound PHilgeman Swap Meet 4 2nd May 2006 01:20 PM
F: great sound control with ECC82 TobWen Instruments and Amps 0 13th September 2004 09:05 PM
This will be a great sound system TomJ Solid State 27 20th February 2003 06:03 PM
Copyright ©1999-2017 diyAudio
