Hi.I want to build a discrete buffer with my components to drive my sennheiser hd25 and other headphones.And also want to use it before amplifiers.I do not want a preamp or opamp based circuit because they have feedback and it lowers bandwith..I had a look at internet but could find a good one.But i need a good schematic.I have these components
1) matched 2sk170/sj74 2) matched bc547c/557c - 546b 556b 3)bd 139/bd140 Maybe can use some other good components too Any suggestions ?thank you very much |
#2 |
a NE5532 + bc546/556 + bd139/140 can make
an excellent class A phone amp, with good bandwith (500khz is enough?) and signal noise ratio (100db) , very low distorsion (0.001%).... |
#3 |
can you post a schematic ?thanks
#4 | |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#5 |
Something like this:
JEAN HIRAGA - Le Monstre Amplifier PCB Though you should increase 1 ohms to 10 ohms
STOP - Hammertime! |
#6 |
umut,
i pôst one that should work very well... BD139/140 must be mounted on smal heatsinks, they dissipate 1 W each... R9 must be settled depending of you phone impedance, you will have to tweak to find the best sound for your taste.. quiescent current can be changed modding R6/R10 , be carefull not to exceed the output devices ratings.. hope that it will help, anyway, the circuit is very easy to redesign according to your exact needs.. |
#7 |
Banned
conceptual proposal with derogative feedback. |
#8 |
Banned
#9 | |
Banned
Gareth,
#10 | |
| Discrete buffer notion | Sheldon | Solid State | 6 | 10th September 2009 03:22 PM |
| Best place for discrete buffer | Khron | Chip Amps | 8 | 11th March 2006 05:16 PM |
| kind suggestion for an high current buffer. | beppe61 | Solid State | 11 | 15th October 2005 06:36 PM |
| Current feedback high speed headphone amp with diamond output buffer | peranders | Headphone Systems | 102 | 30th January 2004 09:53 PM |
| Discrete X-over Buffer from LC Audio-URL needed | Samuel Jayaraj | Solid State | 4 | 9th November 2002 07:59 AM |
| Page generated in 0.11313 seconds (74.06% PHP - 25.94% MySQL) with 11 queries |
