Hi Guys,
i would like to know your opinion on this power amp. The orignal schematic is Mosquito of Jean-Marc Plantefève with mod for vertical mosfet. Now what do you think about these modifications? Thank you! Maxpou |
#2 |
Is the one with the emitter followers the original and the simple one the modified circuit? Or are they both modified?
#3 |
A quite symmetrical design, not bad at all. The emitter follower is necessaryl to
charge the parallelled MOSFET gates in a reasonable time. From that point of view I would expect the left design to exhibit far less output voltage slew rate than the rigtht one. Anyway, a good design imho. |
#4 |
the design of the left doesn t work well with hexfets,
as the vas(s) have high output impedance, inadequate to drive IRFs...the original schematic use hitachi s 2SJ162/SK1038 or the 2sj50/SK135 LATERAL FETS which can be drived in such ways.. the version of the right correct this inadequacy with a buffer.. |
#5 |
Banned
my compromise would be one emitter follower stage. |
#6 |
#7 |
Thank you for reply Guys,
what do you think about Q18, Q19 in my input stage and my output stage without NF? Good or not? Wahab and Lumba: Why only one EF when i read many time here that the best is triple EF? Thank you! Maxpou |
#8 | |
triple EF is said good (although i do not exactly agree with that) for purely bjts outputs... despite needing some high PEAK currents to be drived correctly, the IRFs don t need as much current drive as bipolar s final devices.. |
#9 |
Banned
maxpou,
everything has a price, it is advisable to keep the number of stages small. The drive current is needed to charge the MOSFET input capacitances at high frequencies (sorry no detailed explanation at this time). Linearity will mainly depend on the output stage bias point. Q18, Q19 is OK in conjunction with R4/R5. Could you imagine a folded cascode VAS? Very sensible design and part selection (except BC546). |
#10 |
Hi
Ensure you have very similar IDSSmax for Q16 and Q17. What is the purpose of Q18 and Q19? Q20 and Q21 should be removed as indicated in previous posts. How is done the thermal compensation? (I see a to-92 package for the VBE multiplier) Maybe you want to protect the gates of the IRF mosfet with zener clamping diodes. You can consider using double pole compensation instead of C8 and C9 only. Since you do not show the value of resistors we can not comment to much on the rest. I have made a similar design with the possibility to change the feedback point from overall feedback to non-overal feedback (like yours). Finally, I prefer the sound with overall feedback (feedback at output point). I like the sound of my amp. However, I use 4 pairs of lateral mosfet. Good luck Fab |
| ETI 480 schematic - a thing from the 70-80s | win95_junky | Solid State | 2 | 16th June 2005 09:01 PM |
| power cord break-in or burn-in is there such a thing? | Tony | Solid State | 627 | 4th December 2003 12:05 AM |
| Page generated in 0.09467 seconds (84.60% PHP - 15.40% MySQL) with 11 queries |
