i have a SAE C3A integrated amp that i got froma a friend who said it have a bad channel(R) and only needed one output transistor, i got 2 ecg 381 and 2 d 588, after a replaced the bad channel transistors i powerd the reciver and it blew both protection fuses, i desolderd the 2 just repaced transistor and put back fress fuses and i powerd again the amp and it did not blew any of the fuses. the left channel sounds ok but my right channel has no audio in the preamp stage but left does have. can somebody give me pointers in what might be wrong whit the amp and what to look for. my friend says tha the Ha 1457(ecg 1666) is bad is this ic could be the problem?
#2 |
Firstly - stop using NTE/ECG parts, they are useless.
#3 |
i cant find original parts. they are kind of hard to find so i use what i have available.
#4 |
You need to take a step back and get it working without output transistors.
I usually remove the output transistors and feed the VAS output back into the LTP feedback. Then check the bias voltage is not silly and check the DC offset is not silly too. If the bias circuit is faulty then you will just keep blowing output transistors.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#5 |
Here is a list I put together for SAE (Scientfic Audio Electronics) with the help of James Bongiorno, the amps designer.
SAE Audio Repair Tech Info - Part Number Cross Reference Table |
#6 |
that it was i has done so far i desolderd the output transistors in the right channel and powerd again and it did not blew the fuses, i left the left channel transistors because it works fine. the problem is in the right channel. like i said im working whit a friend of mine that has more knoledge that what i have in electronics i will let him know. thanks for the help so far.
#7 |
well i have replaced the preamp ic(HA1457)and 2 disc capacitors_3 and 20_.and the 4.3volts i had in the right input at the amplificatin side is gone.now i have audio on the right side(whitout the power transistors) but the sound is kind of low compared to the left side at amplification side. i have chequed the resistors,diodes in the right amplification and preamp and they read good. does anybody knows what causes low volume in the right channel amp side compared to the left? thanks for the help.
| MC2105 blows fuses on powerup | philosophy | Solid State | 18 | 10th October 2009 03:22 AM |
| Gallien Krueger 700RB blows fuses | dthnut | Solid State | 1 | 9th May 2008 12:54 PM |
| TOA W906-A amp blows fuses | ajm14120 | Solid State | 5 | 15th October 2007 10:29 AM |
| Amp Shuts off or blows fuses | Oddy88 | Car Audio | 6 | 2nd August 2007 08:33 PM |
| amp blows fuses at turn on where should I start looking? | spooney | Solid State | 17 | 23rd December 2006 07:44 PM |
| Page generated in 0.10062 seconds (76.31% PHP - 23.69% MySQL) with 10 queries |
