#101 |
lgreen,
I used Mouser part no. 576-01000054N for my SymAsym boards and I picked this Littelfuse model because it is silver-plated. I believed that 576-01000054N is out of stock at Mouser but the part number 576-01000054H should have the same dimensions. - Stanley |
#102 |
Hi Al,
I have a box of some generic red, green and yellow LEDs. Can I use these or should I stick to the particluar make you have specified in the BOM? cheers Aidan |
#103 |
Hi Aidan,
Do you know the LEDs forward voltage? If your not sure connect the LEDs cathode to about a 5k resistor and then a 12V supply and measure the voltage from the cathode to ground. If the voltage measures around 1.75V to 1.85V they should work fine. If not you may have to adjust the front end bias resistor R19 to compensate. Regards, Al
Love when you can, Cry when you have to, be who you must, that's part of the plan. |
#104 |
Boy it's been awfully quiet out here this week. Stanley (sng001) was the first out of the gate that I know of, how are the rest of you doing with the amp assembly?
Regards, Al
#105 |
Not that I'm working at the Amp at the moment, but I'm here to support you, Al
#106 |
Thanks, I need all the support I can get.
#107 |
Hi All
I just finished a low power version of my DTV Rev_1.3 PCB with the same amplifier circuit but with only a single OT pair and no on-board PS. The PCB measures only 2.5" (63.5mm) x 2.95"(75mm) which is perfect for a home theater amp using an external PS. The PCB provides provisions in the OT section to accept Lateral Mosfets for an all input/output fet operation. Attached is a picture of the PCB and schematic. Since this is a low power version I dropped the rails to +/-36V and bypassed the differential/VAS cascodes. From my testing bypassing the VAS cascode increases 2HD resulting in a softer sweeter sounding amplifier. Al
#108 |
Need time to take appart budget to acheave mouser purchase for three DTV.....
Marc |
#109 |
Hi Marc,
I guess you gotta do what you gotta do. Waiting patiently... Regards, Al
Love when you can, Cry when you have to, be who you must, that's part of the plan. Last edited by AAK; 12th February 2010 at 07:16 PM. |
#110 |
During i'am working on amp layout. I drawn a PSU board to use MBR20_200CT i have on hand (25 unit). That will just nice for three psu board with double rectifier bridge.
![]() ![]() I will screw MBR on main heatsink, they will be solder under PCB board, same way as OUTPUT transistor on main amp board. Marc Last edited by Idefixes; 12th February 2010 at 07:21 PM. |
| Symasym 5.3 "AAK model" builder's thread | MBK | Solid State | 719 | 23rd March 2013 10:52 AM |
| SymAsym - The Sequel, AAK's PCB GB | Piersma | Group Buys | 226 | 24th February 2011 07:33 PM |
| Where in Europe do you buy your 2SC5200-O and 2SA1943-O for AAK's Symasym boards ? | rephil | Parts | 9 | 31st March 2007 03:24 AM |
