Old 18th January 2010, 08:46 PM   #1
timwebb is offline timwebb  United States
Default bias transistor
what would cause the biasing transistor blow on an amp?
Old 18th January 2010, 09:08 PM   #2
wahab is offline wahab  Algeria
too much current, wether it comes from the vas or
a failed current source, or even from the following stages,
drivers + power devices...
it can also be that it has too much voltage across his
emitter and collector, but by the time this happen,
the output devices would have blown well before, generally...
Old 18th January 2010, 09:27 PM   #3
could a bad driver cause this
Old 18th January 2010, 09:37 PM   #4
without schematic, it s difficult to have a precise clue.....
Old 18th January 2010, 09:41 PM   #5
in usual circuits you'd need both + and - drivers shorting collector to base without the collector to emitter current shutting down the power supply very quickly. Pretty rare. Other than that you'd need very large currents coming out of the VAS.
Old 18th January 2010, 09:58 PM   #6
one of the drivers shorted just didnt blow. a resistor blew that connected them both. im going to change them and see what happens
Old 18th January 2010, 10:01 PM   #7
I'd proceed on that one with extreme caution. If you cooked one driver and the bias transistor, that fault current must have gone Edit: somewhere.
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Can TL431 be used as a bias transistor?? Leolabs Solid State 5 15th January 2009 08:51 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 23 16th February 2008 12:35 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
Page generated in 0.08225 seconds (82.52% PHP - 17.48% MySQL) with 10 queries
