Anyone out there have any idea if there is any general correlation between amplifier life span
and its wattage rating? (I am referring to class A/B solid state amplifiers.) Or worded another way, will a 50 watt amplifier be less likely to have various component failures over time compared to an equivalent quality higher wattage 200 watt amp? My thinking: will the higher wattage and higher voltages have an effect on the life span of power transistors, power supply capacitors and so on due to thermal stresses (more heat) and so on. This is probably not an easy question to answer, but perhaps there are some experienced DIYers, designers or technicians out there that have some insight. Ron |
#2 |
If your running components near to their limits you are more likely to have problems.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
The failures that I've seen before are normally electrolytic capacitors that have dried up, over-heated mains transformers, and solder dry-joints. Most of this seems to have been associated with running things at too high a temperature / unventilated.
If things are well designed and have some protection system and good ventilation then I think they can run for many years. Mind you, I don't know much about semiconductor quality, so maybe there is some form of aging process / heat cyling thing that leads to failure? J. |
#4 |
I don't think there is any correlation between power output and life span. Bryston for instance gives 20 (transferable) guaranty on all their power amps regardless of output which ranges from 100w/8Ohm to 1000w/8Ohm.
#5 | |
Jim J. |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| 300B PP bias and expected life time | jogas | Tubes / Valves | 3 | 27th January 2005 10:02 AM |
| Page generated in 0.09215 seconds (74.99% PHP - 25.01% MySQL) with 10 queries |
