does early effect shift much within a device family?
Old 19th January 2010, 04:16 PM   #11
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
uncle,
you are complicating this unnecessarily. Visual inspection and crack-up are the best way to go.
Old 19th January 2010, 04:23 PM   #12
Andrew Eckhardt is offline Andrew Eckhardt  United States
By "crack-up" do you mean vise or hammer? Because that's what I would do.
Old 19th January 2010, 05:09 PM   #13
Banned
Right, then you will know for sure.
Old 19th January 2010, 05:30 PM   #14
wg_ski is offline wg_ski  United States
Originally Posted by Lumba Ogir View Post
uncle,
"Break one open and look inside" may not fly with the ISO9000 auditors or the bean counters.
Old 19th January 2010, 05:34 PM   #15
Tell them fine, you'll do it once they come back shorted.
Old 20th January 2010, 12:26 AM   #16
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
actually, the companies that do this for a living use X-ray machines.... i do know a doctor or two that have one...
Old 20th January 2010, 01:28 AM   #17
I don't know if you can turn a medical x-ray source up high enough to punch through a good layer of copper. Maybe you could set the pulse duration to maximum and try multiple exposures. It seems like the cost of one crumbled transistor from an order-full would be worth it.
Old 20th January 2010, 02:54 AM   #18
The FA place we use sells X-ray machine time at $100 or so an hour, after hours. The X-ray will go right though copper - the harder alloys like Cu-W, not so much.
Whether the cost of one sacrificed transistor is worth it or not depends on how many you're ordering and how rare they are. For current production parts in 100 piece lots no problem. They're not likely to be fake anyway, and checking one isn't an issue. But if you're using obsolete devices that you obtain a few at a time, and can only get them from questionable sources it's another matter. Just when you need to the most you can't afford to bust it open. And whether or not your QA policy will allow it.....
Old 20th January 2010, 03:12 AM   #19
Banned
it is wise to be cautious and suspicious about low prices these days, Sanken devices are usually not cheap.
does early effect shift much within a device family?Hide this!Advertise here!
this may be a stupid Q on Spawn Family paba Full Range 12 14th May 2009 12:01 AM
Family that sings together... Raka Solid State 6 23rd March 2005 11:16 PM
The (small) Aleph Family Antonio Pass Labs 14 12th January 2005 07:56 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 09:37 PM
TDA1541 family tõnu Digital Source 7 29th March 2002 05:02 PM
Copyright ©1999-2017 diyAudio
