Old 17th January 2010, 03:38 PM   #1
Default audio analyse' - French made amp?
hi,
Audio Analysé is a French company from the 80 - who knows some thing about this amp?
i think that today is metronome-technology, but there is no trace back to it.
it has a very good sound, i am looking for the schematics of the power amp!
best regards,
Williams
williams audio
Old 17th January 2010, 05:22 PM   #2
forr is offline forr  France
forr's Avatar
This is the only schematics I have.
Audio Analyse amps were class A. Famed in France for excellent sound but very unreliable. Some people incriminate insufficient cooling, I think there could be a thermal cycling problem. If you own one, I suggest you find a way to decrease the power supply voltage.
Old 17th January 2010, 07:56 PM   #3
hi forr,
thanks a lot, this amp is very, very hot i think to add some forced ventilation
best regards,
Williams
williams audio
Old 17th January 2010, 08:15 PM   #4
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Williams ,
How much power is the amplifier ? ...
Old 17th January 2010, 08:19 PM   #5
wahab is offline wahab  Algeria
kinda strange thing on the schematic..
the negative feedback is took after the output protection
fuse...if this one blow, the amp will be forced into open loop
configuration..
Old 17th January 2010, 08:54 PM   #6
Nrik is offline Nrik  Denmark
configuration..
...which probably wont do much harm, since the output then is unloaded.
And the reason for doing so is ofcourse to remove the sonic influence of the fuse.
STOP - Hammertime!
Old 17th January 2010, 09:09 PM   #7
yes, although i woudn t waste negative feedback to correct
a fuse nonlinarity...a relay would be a far better solution, moreover as
this is supposedly an audiophile oriented item...
Old 17th January 2010, 09:30 PM   #8
forr's Avatar
Add a resistor of a few hundreds Ohm and enough wattage across the fuse. In case of blown fuse, the feedback loop is maintained, the blown open fuse closed loop gain then having just a little bit more value than the passing fuse closed loop.
Old 17th January 2010, 09:37 PM   #9
...but on the other side of it there is 4-8ohm to ground = circuit is still open looped.
STOP - Hammertime!
Old 17th January 2010, 10:16 PM   #10
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The A9 does 60W in Class AB, 50W brochure spec.(Biggy A90 goes 120W, 50 in full Class A)
90W of heat on 160VA toroids in the A9 is pushing it, even if biased only to 25W continuous.
Schematic of the B90/P90 power amp section, 10W Class A and 100 in AB=>
Looks like Sponge Bob has killed another thread.
Please help analyse 807 PPP cjcc67 Tubes / Valves 38 2nd November 2009 08:04 AM
I want a home theater made with car audio! Rockworthy Car Audio 16 10th October 2009 10:30 AM
Car Audio Amplifier business made in USA boxcustom Car Audio 21 26th September 2009 12:30 PM
I made myself a forum - for audio projects lineup Everything Else 1 12th August 2008 01:23 AM
New loudspeaker ATHOM made in french ;) mezzo Multi-Way 0 21st April 2003 12:37 AM
Page generated in 0.10575 seconds (75.51% PHP - 24.49% MySQL) with 11 queries
