Old 5th October 2011, 06:37 AM   #11
Mooly's Avatar
If in any doubt measure the voltage across the caps with the amp on to see what you are dealing with. Circuit diagrams are not always correct particularly when regional/country variations are taken into account.
If the caps really are 75 volt and original then there is absolutely no problem fitting 80 volt devices.
Bypassing with a film does nothing with regard to voltage ratings. It's only of use in reducing the impedance of the supply at high frequencies... which probably isn't needed as there will be more local decoupling in the amp.
A simulation free zone. Design it, build it, test it.
Old 5th October 2011, 11:11 AM   #12
AmCan is offline AmCan  Canada
Thank you Mooly, I really appreciate it. I will measure the voltage.
Old 5th October 2011, 12:18 PM   #13
sreten is online now sreten  United Kingdom
Hi, 80V capacitors will be fine on +/- 55V rails, rgds, sreten.
Bypassing is pointless, look at the main board decoupling arrangements.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 5th October 2011, 02:12 PM   #14
If you use the maximum line voltage you ever expect to see for moderate durations (ignore spikes), and under unloaded conditions for the PS, that should give a reasonable minimum for the cap rating. Most of the time it will be operating with a generous factor of safety and will even be OK if the circuit is disconnected. Most caps also have a higher surge rating, so the FOS is actually even better. The manufacturer has already put in some margin because building caps isn't as precise or consistent a business as one might hope.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 5th October 2011, 02:40 PM   #15
Thanks guys, I appreciate that not only have you answered my question directly but I have learned something about making determinations.
I also like my Canadian flag up there I just noticed that.
Old 5th October 2011, 03:03 PM   #16
Conrad is correct.
One must look for worst case operating conditions and design for those eventualities. The design decision could be to accept that some conditions are acceptably rare that the designer accepts responsibility for future failure when the foreseen risk is achieved. That's part of what a Manufacturer's warranty is about.
Guessing at a Factor of Safety (FoS) does no good. Determining a FoS based on testing and experience and actual variations in product specification is quite different.
There can never be an assurance that a guessed at FoS of 1.3 (that's 30% over the rating) will prevent failure. Particularly so when the worst case conditions may already exceed the "normal" operating conditions by more than that 30%.
regards Andrew T.
Capacitor voltage rating conversion alexg Tubes / Valves 3 26th July 2008 04:24 AM
PS Capacitor Voltage Rating dsavitsk Tubes / Valves 3 16th January 2006 02:37 AM
Oil Capacitor DC vs. AC Voltage Rating valveitude Tubes / Valves 2 10th June 2005 11:45 PM
Capacitor Voltage Rating diyman Solid State 2 21st December 2004 02:49 PM
Capacitor Voltage Rating Super_BQ Parts 14 22nd September 2001 03:50 AM
Page generated in 0.08476 seconds (75.68% PHP - 24.32% MySQL) with 10 queries
