OKI DOKI
this is the simplest tone control ever ...the particular also seems to have some gain also ....it doesnt get any simpler ... Question 1 if a thing like that is made with the best available psu and the best available material can it be called an audiophile tone control ?? or simply to have a good quality tone control you need symetric psu and op amps . Question 2 I have one Yamaha amplifier that uses a "passive tone control" that takes feedback from the aoutput to operate i presume that in this topology will be impossible to seperate preamplifier and main amplifier ( unless you keep the main amplifier operating to support the tone control and then take the signal from the amplifier input to drive another amplifier ) opinions please thanks
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 | |
jd
/Another new issue: Linear Audio Volume 3! |
#3 |
OK GOT IT ....
is this regarding question one or question two ???
#4 |
Hi sakis
Yes I think janneman refers to question 2. Having the control in the feedback loop is not good. Each time you adjust the tone control your'e changing the working condition of the amplifier. The amplifier may measure good with the controls in flat position, however changing the setting of one of the controls, the amplifier got a new working condition which may result in higher TIM, IMD and changed FRC......... Better to have the controls in the front end of the amplifier (preferably with a output buffer), where you can control the impedances
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#5 | ||
Magneto the Gravity Man
Can any "tone control" be called audiophile ? Andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#6 |
hello sakis,
im intersted to build this tone control for my amplifier, can i have the complete part name of transistor use? and if possible the pcb layout.PLS Regards, Ronald |
#7 | |
the transistor is bc 547 or 548 no pcb for that
| Baxandall tone control circuit | mckvak | Solid State | 5 | 23rd October 2009 02:05 PM |
| which tone control circuit? | ruleworld | Chip Amps | 20 | 21st July 2009 04:24 AM |
| hi quality tone control circuit | space2000 | Solid State | 0 | 2nd April 2008 12:02 AM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| OP AMP Tone Control Circuit Problems | NickC84 | Parts | 4 | 22nd July 2005 03:17 PM |
| Page generated in 0.10552 seconds (75.96% PHP - 24.04% MySQL) with 11 queries |
