Hey
I really need some help with my high THD ... i really dunno what happen to my High THD can anyone help me giving me some advise with 10hz THD is 0.0006% .. but i simulated a 73% for the Blameless power Amplifier. I really need some help since I have stucked. Below is the Blameless.asc and also the Diagram of the THD result . Mind everyone for the help! ClassB(THD8ohm).txt 121212123.JPG |
#2 |
add .options plotwinsize = 0 to your spice diagram. also you will have to simulate at a small timestep like 0.05u.
Post your LTSPICE .ASC file and we can help more |
#3 |
The models used were not included so I couldn't test your simulation but with a simulation length of only 15ms you are not going to get any information on the 10Hz distortion.
The bewitching snivvie is dulcet paragon. |
#4 |
This gives sensible results:
.four 0.01kHz V(OUTPUT) .tran 0 500m 100m 0.1m |
#5 |
Well, the output clearly shows he's simulating 10kHz, not 10Hz. That's a much more reasonable number.
Likely you're DC-operating points are completely banana. Always distrust the computer. Have fun, Hannes |
#6 |
Oh, that's right too. There is a mismatch between the signal source which was set to 10 Hz and the .four command set to 10 kHz.
#7 | |
What does it mean by DC-operating points are completely banana? How does it know ? |
#8 |
#9 | |
IS the input voltage frequency should be same as 0.01K for the command of .four 0.01kHz V(OUTPUT)? Are they the same? |
#10 | |
However, first you should read the wikipedia-article on distortion I'm sure then it's more clear what signal to put in (1kHz) and what to analyze for (1kHz). Have fun, Hannes |
| Blameless Amp layout | Ipanema | Solid State | 83 | 11th March 2010 08:13 PM |
| A tubular 'Blameless' | GK | Solid State | 46 | 25th January 2010 11:53 PM |
| Please, help me with Self Blameless | Ric_rock | Solid State | 45 | 13th January 2010 04:03 PM |
| Transistors for Blameless | tommytube | Solid State | 2 | 3rd May 2007 08:10 AM |
| Page generated in 0.10684 seconds (78.64% PHP - 21.36% MySQL) with 11 queries |
