| View Poll Results: Burning/running in? | |||
| Fact? |
21 | 42.86% |
| Fiction? |
28 | 57.14% |
| Voters: 49. You may not vote on this poll | |||
In my last thread I asked what burn/run in times should be expected of new equipment, I realise now that I should have actually asked if folk believe it to be fact or fiction, so here goes....
Do you see burning/running in of new equipment as fiction? Or; Do you see burning/running in of new equipment as fact? If so, what would you say is to be expected and after what amount of time? Namely in; 1. Solid state amplifiers 2. CD Players 3. Speakers 4. Interconnects 5. Speaker cables I'm undecided myself so looking for as broad an answer as possible. I'm not looking to start a 'post war' though, so please refrain from attacking others for expressing their opinion, afterall, they're only opinions. Thanks |
#2 |
Fiction for everything but speaker drivers but it seems impossible to express that in this overly simplified poll.
#3 |
Thank you for your input. I'm sorry you do not favour the simplicity of my poll, I kept it simple with no specifics to hopefully recieve as broad a reply on burning/running in as possible.
#4 |
Fact for mechanical parts.
Fiction for electronic parts. Replies should be as simple as possible but not simpler
I use to feel like the small child in The Emperor's New Clothes tale |
#6 |
#7 | |
Electrolytics need to be formed, yes. Could probably be seen as a form of burn-in. Don't forget that the original meaning of burn-in was the process to weed out early failures in equipment ('infant mortality'). You would fire up your amp for several hours or days and if it survived, it was deemed to be reliable and thus burned-in. With expensive equipment, it is often done in the factory to avoid shipping products that fail within a few days at the customers place. Mil spec equipment is routinely burned-in. jd
/Another new issue: Linear Audio Volume 3! |
#8 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#9 | |
Thanks |
#10 |
Indeed. Having just spent the past five working days refurbing two 18" drivers that don't have the correct spare parts available any more, each bit of work required an hour or so running on sine wave to check each stage had bedded in properly. Just about all of them needed tweaking after testing.,
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| Burning/running in times? | nad | Solid State | 181 | 25th January 2010 02:56 AM |
| Extemis - Fact of Fiction | sbolin | Multi-Way | 15 | 23rd January 2005 03:29 PM |
| Found on Ebay - fact or fiction? | Nuuk | Multi-Way | 53 | 24th April 2004 06:10 PM |
| Page generated in 0.11528 seconds (80.89% PHP - 19.11% MySQL) with 12 queries |
