It is hard to search for good Audio Mosfets-may be because of my lack of experience or knowledge
I am looking for better mosfet sub on rail voltage of +- 80v amp. Thank you in advance |
#2 |
Toshiba 2SJ201 and 2SK1530 are a very good choice in my opinion.
#3 |
J162/K1058 can't properly handle 80Vdc rails.
If you prefer to stick to Lateral MOSFETs you're better off with Exicon ECX10N20/ECX10P20, TO247 package equivalents of the 200V Hitachi J56/K176. Can be ordered direct from Profusion in the UK.
Looks like Sponge Bob has killed another thread. |
#4 |
They can't handle 80V rail. now I know because I smoked few. Thanks for quick reply
#5 |
Banned
birdyman,
2SK2220/2SJ351. You won`t find any better. |
#6 |
#7 | |
Dear Jacco, Would you kindly tell me why the K1058/J162 can't handle 80V? The datasheet says max 160V. I have 8 pairs of these and therefore it would be good to know the safe max. voltage. Thanks! |
#8 |
Banned
wahab,
the 2SK2220/2SJ351 is a more closely matched pair due to improvement of the P-channel device. Look at the value of Crss. |
#9 |
well, all the other parasistic parameters , Ciss and Coss are no better, and even worse
on the 2220/351....all in all, i would stick with the 162/1058 if ever they are cheaper.. myself i use the now obsolete TO3 variant of these devices, and i can tell you, they are very rugged and very good sounding.. |
#10 |
Basic power supply reason, the rail voltages will fluctuate due to variations in the mains plus transformer regulation.
Hong Kong mains power is 220Vac with +/-10% bandwidth, so mains voltage can range between 198Vac and 242Vac. Common regulation numbers for toroidal transformers are 4.5% for a 500VA, 4% for a 750VA, 3.5% for a 1000VA. On fast transients, output voltage can be close to rail voltage with the opposite output device opened, Vds close to 2*Vrail. J162/K1058 can handle a max Vds of 160Vdc, so rail voltage level should not go above 80V. Using a 500VA in Hong Kong boils down to nominal rail voltages of +/-70Vdc. (70 + 14.5% makes 80)
| 2SJ162-E and 2SK1058-E | 1965GTO | Vendor's Bazaar | 4 | 26th March 2012 01:38 PM |
| Pictures of the 2SK1058/2SJ162? | whalefat | Solid State | 54 | 26th October 2009 04:50 PM |
| 2sk1058 and 2sj162 subs | rtill | Solid State | 6 | 13th March 2009 04:47 PM |
| Anyone know where to get 2SJ162/2SK1058 | fossil2k | Solid State | 8 | 17th March 2008 12:07 PM |
| 2SK1058 2SJ162 Complement Pair | Minh | Solid State | 1 | 16th November 2001 04:09 PM |
| Page generated in 0.10050 seconds (75.96% PHP - 24.04% MySQL) with 10 queries |
