Looking for the schematic of the old Tigersaurus. Built one of these in the mid 80's (mono for subwoofer drive) from an article in Radio Electronics. No longer have that magazine, and want to get it up and running again.
Doug |
#2 |
Send me your email, I have the whole manual loaded and ready to go.
Craig |
#3 |
Googled the tigersaurus and it doesnt look good !
Taming the Tigersaurus [Archive] - AudioKarma.org Home Audio Stereo Discussion Forums
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
Never had trouble with mine. In my tech days I used to upgrade circuits in equipment, so I overbuilt mine a bit. It was used for 10 years, then set aside. When I fired it up a few weeks ago, it didn't work. So now I get to fix it.
#5 |
Radio Electronics December 1973
That circuit gives me the creeps. Sziklai output stages are tricky at the best of times, but with the output transistors on long wires... *shudder*, no wonder they used to explode! The cascode arrangement in the output section seems silly to me... while there are current sharing resistors at the top of the cascode devices, these are then negated by the cascode devices collectors being tied together. Those RCA transistors are likely to be unobtainable unless you want to risk eBay. |
#6 |
Agree with what you say. My output transistors were mounted differently than shown in the article, And I used a pcb of my making to attach them, and kept the wires short.
#7 |
Doug,
I have the Tigersaurus assembly manual from SWTP. Let me know if you want it. Craig |
#8 |
Thank you, I managed to find the original assembly article from Radio Electronics online.
I've already noted a few more ways to improve it, hopefully. Although the way I built it turned out stable, a few more improvements aren't going to hurt it. |
#9 |
the output compound pair is with voltage gain
to compensate the +- 10V loss in the dual differentials collectors resistances... this will amplify the thermal shift of the output stage.. not to mention that it s more prone to oscillations than an emitter follower, not even counting the tricky compensations schemes.. no wonder that some builders have instability issues with it.. |
#10 |
Yep, prefer emitter followers myself, but I got this one working fine when I originally built it.
| new member | baird | Introductions | 6 | 14th July 2008 04:42 AM |
| Replacing Hafler 9130 transistors- 2 techie question | reiver | Solid State | 5 | 12th June 2008 12:15 PM |
| New member says hello! | colinB | Introductions | 3 | 26th May 2006 01:34 PM |
| Welcome a new member from D.C.! | Septimus | Introductions | 7 | 22nd February 2005 02:51 AM |
| a new member | sayedtalaat | Chip Amps | 1 | 5th December 2003 09:44 PM |
| Page generated in 0.10310 seconds (78.65% PHP - 21.35% MySQL) with 10 queries |
