Old 13th January 2010, 07:31 AM   #1
sakis is offline sakis  Greece
sakis's Avatar
Default piezo electric tweeters
i have an application in a big area with almost 80 smal 100v 25W 2way 4" speakers + a very small tweeter
80 speakers are working with 5-6 amplifiers without a limiter ( 100v procedure ) that had the result that 80% of the very small tweeters are blown
now, for sure this is a very lowfi application that only is used to anounce in a big area a few voice messages and may be some radio music ....
as we speak and with 80% of the small tweeters blow the sound is really terrible so i was thinking first of all to install a limmiter then again replacing 80 small tweeters is a real pain in the *** and very time consuming , then again i thought like instaling 4 big piezos conencted inseries with each others in selected spots to introduce some high in the area
question :
do you think that if i use one resistor say 10R 15W one capacitor in series say 2.2 mfd 250V mkt and 4 piezo in series do you think i will get away with it without an 100 volt transformer ?????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 13th January 2010, 09:12 AM   #2
tiefbassuebertr's Avatar
start this thread again about
>Forums >Loudspeakers >Multiway > piezo electric tweeters
here is this pad:
>Forums >Amplifiers >Solid State >piezo electric tweeters
By the way - frequency response of one tweeter could be helpful
Old 13th January 2010, 09:21 AM   #3
sakis's Avatar
posting in solid state is because this is not exactly a "speaker issue " also 100 v technology has not much to do with speakers guys
mostly is about tech guys that constructed 100 V systems performd both installations and tuning in large areas and so on
also qualities and performance of crappy piezo tweeters is well known between solid state forum members so i dont realy get your point
Old 13th January 2010, 01:11 PM   #4
Rafael L's Avatar
Hi Sankis
The TWs piezo has high sensitivity and a small margin response in HF. You must decrease the sensitivity with a L-Pad and cutting the filter above >5KHz,
The sound will be bad, if you do not do this.
Old 16th January 2010, 01:07 PM   #5
sakis's Avatar
ok took my chances installed that directly to 100 volt line and all went very smooth
i added to the system exactly what was missing
working .....
How well do piezo tweeters do skooter Car Audio 2 2nd September 2008 09:05 PM
Piezo vs electromechanical tweeters polsol Multi-Way 50 6th June 2006 09:07 PM
Anyone Know Le'Son Ferro-Electric Tweeters? Zero Cool Multi-Way 5 4th March 2005 06:59 PM
Piezo Tweeters subwo1 Everything Else 6 22nd August 2002 11:46 PM
Using piezo tweeters Rory Multi-Way 15 6th November 2001 08:46 PM
Page generated in 0.07505 seconds (72.43% PHP - 27.57% MySQL) with 10 queries
