I just picked up a Yamaha 2010 amp that powers up but will not put out any sound. Checked all fuses and circuits, all are fine. Switched speaker outputs, nothing. Any clues as to what the problem might be?
#2 |
is there an input signal level indicator?
Next step involves lethal voltages. What tools do you have (scope, DVM, generators, loads) If it's totally DOA then there's probably burnt bits inside. Can you post pics? |
#3 |
at this age its is almost a fact that this amp will need an extremelly good cleaning regarding pots and switches
beyond that, dirty trimmers and all electrolytic capacitors will need to be replaced ( against some peoples opinion this is also a fact ) after that and while replacing the above you will be able to : repair any other damages that exist upgrade some parts any way here is a usefull link vintage amplifier repair/upgrade manual
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#4 |
Thanks Iain, I'll take some photo's and post tonight.
#5 |
Hi Sakis, thanks for your post. Very helpful. I've cleaned all switches but am not sure how to clean the ALPs pots as they are completely sealed. There does not appear to be any visually burnt components, but I am wondering if the speaker relays might be corroded and stuck. Apparently there was some distortion on the left channel, until the volume was turned up, then it cleared. The system has sat dormant for five years, now no sound. The next step might be taking it to a qualified tech with real testing capabilities. I still hope it may be something simple and within my capabilities.
Brian |
#6 |
99% chance that the caps in the relay circuit are dried out.
Replace them.
Candidates for the Darwin Award should not read this author. |
| Yamaha 2010 - no sound | brijan.koldijk | Solid State | 0 | 13th January 2010 01:00 AM |
| Yamaha digital sound projectors | gvr4ever | Multi-Way | 2 | 15th August 2006 11:49 PM |
| yamaha amp scratching sound | ihodiputah_510 | Solid State | 2 | 22nd April 2006 08:43 AM |
| Digital Sound Projection from Yamaha | AAK | Multi-Way | 1 | 12th April 2005 08:34 PM |
| Yamaha A-760 of the Natural Sound range | Layberinthius | Solid State | 0 | 21st March 2004 11:06 PM |
| Page generated in 0.09793 seconds (80.93% PHP - 19.07% MySQL) with 10 queries |
