a hundred questions from a noob
Old 30th May 2003, 05:36 PM   #1
zoobie is offline zoobie  Canada
Default a hundred questions from a noob
hi all. I just picked up a cheap H/K PM665 from a guy who knows even less about electronics than me. I have a few questions about it - there seems to be some weirdness with the balance and the bass contour switches. I don't know - maybe I should replace both? Where is a good place to buy them from?
If I want to mod this amp, where is a good place to start?
Here are the internals. It looks pretty mean, but wtf do I know. :
Thanks in advance for helping another noob enter the hobby.
Old 30th May 2003, 08:37 PM   #2
here is what the bass contour switch looks like:
Old 30th May 2003, 09:48 PM   #3
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hi, zoobie
What a beauty!!!
I guess the contacts from the switches are dirty or maybe worn out.
Look at the solderings of the pots and switches and redo them if necessary. Be prepared to remove a lot of screws, and remember where which screw fitted. Make a drawing.
I wont be an easy task to find replacement pots or (and) switches, unless you can order them from HK.
The best thing to do is replace them, if the solderings are ok.
You could try "contact cleaner", but it would be a shame to blow that spray in such a nice amp. Personally, if I have no other choice I used that spray in very small amounts. There is also a second spray, which washes away the "contact cleaner". Only consider this as a last resource!
Don't hurry; take your time. It's a very nice amp.
/Hugo
Old 30th May 2003, 09:55 PM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Looks nice
you can get owners manuals and such from here
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 31st May 2003, 01:28 PM   #5
Thanks alot for the help!
Old 31st May 2003, 02:04 PM   #6
jean-paul is offline jean-paul  Netherlands
jean-paul's Avatar
You can get the service manual + schematic here:
http://manuals.harman.com/hk/Service...pm665%20sm.pdf
It's only audio. Member of the non modular PCB design committee
a hundred questions from a noobHide this!Advertise here!
Noob questions about a K-12/K-502 kit poynterama Tubes / Valves 6 20th August 2008 10:54 PM
Yet Another Set of Noob GC Questions Thomo Chip Amps 2 23rd February 2007 12:10 PM
Noob questions deriver23 Car Audio 1 25th August 2006 11:06 PM
Noob Questions... MrGeebs Solid State 7 24th March 2006 03:17 AM
