Old 10th January 2010, 12:31 AM   #1
Question finding solid state amp output resistance, ohms
Hi there: Hornresp TH program perameter requires the amplifier (solid state) output resistance in ohms. When this parameter is unknown, how can the resistance be determined, without damaging the amplifier? ( no manual is available for a Harmon Kardon HK870 ) ...regards, Michael Droke
Last edited by j.michael droke; 10th January 2010 at 12:32 AM. Reason: adjusted format
Old 10th January 2010, 01:13 AM   #2
djoffe is offline djoffe  United States
Default There are ways, but...
For a typical solid state amplifier, you could assume about 0.1 Ohms. There is also a spec sometimes given, called damping factor. Damping factor is the ratio of some reference load resistance, typically 8 Ohms, to the output impedance of the amp. So, a damping factor of 80 would mean 0.1 Ohms of output impedance.
In general, the output impedance is a function of frequency, but you might not have to get that sophisticated.
If that's not good enough for now, I can respond with a procedure to make the measurement.
Old 10th January 2010, 02:22 AM   #3
cbdb is online now cbdb  Canada
Most SS amps have output resistors that limit the output impedance and are a good aproximation of it. They are usualy low value (.1 or.2 ohms) larger power resistors near the amp outs and there should be 1 per output transistor. If you have multiple output transistor pairs per channel than these resistors values are in paralell. So if the value of one resistor is .1 ohms and the amp only has one pair of output transistors the output impedance is about .1 ohms, two pairs would be .05 ohms, 4 pairs .025ohms etc.
Old 10th January 2010, 06:18 AM   #4
Yea probably be safe to just use .1ohm for your calculations except if you are going
to use a passive crossover you will also need to include the dc resistance of your choke too.
Old 10th January 2010, 06:41 AM   #5
Mooly's Avatar
These are "emmiter resistors" used for bias/temperature stability and have no bearing on the output impedance of the amp because they are (in 99.9% of amps) within the global feedback network.
Old 10th January 2010, 12:52 PM   #6
forr is offline forr  France
forr's Avatar
Fit a 10 Ohm, 10 W or more, power resistor at the amp output.
Set an input sine signal such as you get 10 V across it.
There is 1 A in the circuit.
Remove the power resistor, the amp output voltage should be a few mV higher, let's say 10.1 V.
This means than there is 0.1 V voltage drop across the internal impedance of the amplifier when 1 A is delivered.
The amp ouput impedance is then :
0.1 V / 1 A = 0.1 Ohm
This is Ohm's law
You can change the value of the resistor and the signal and do the calculations accordingly.
The ouptut impedance slightly changes with frequency, but, as already stated, if it is 0.1 Ohm or lower at 1 kHz, you can consider it as null.
Old 10th January 2010, 01:29 PM   #7
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
manual is available for a HK870
El manuál de servicio for Otala's Speedy Gonzales amp is here :
http://www.audio-circuit.dk/Schemati...870-pwr-sm.pdf
Looks like Sponge Bob has killed another thread.
Old 11th January 2010, 01:37 AM   #8
Hi There: Thanks to all responders for the information about amplifier output resistance and the HK870 manual. ... Michael Droke
What Solid State Amps with Output Transformer do you know of? Onvinyl Solid State 27 27th April 2010 10:41 PM
Solid State amp with output transformers vizion Solid State 31 10th November 2007 03:23 PM
Transformer output solid state lumanauw Solid State 34 3rd April 2007 02:14 PM
Page generated in 0.10228 seconds (80.14% PHP - 19.86% MySQL) with 10 queries
