anybody have a spice model for 2SA1407 and 2SC3601?
after seeing some threads were these are mentioned as having sweet properties i would like to try them out... Thanks Icko |
#2 |
.subckt Q2SC3601 C B E
+ params: + IC_VBE=1.10250E-36 + IC_VCE=1.10250E-36 + STATE=1 + TEMP=0 + AREA=1.0 + STATE_FACTOR=0 + IS=20.9E-15 + BF=95 + NF=1 + VAF=80 + IKF=0.2 + ISE=0.0 + NE=1.5 + BR=0.2138 + NR=1 + VAR=20 + IKR=0.5 + ISC=0 + NC=1.0 + RB=4.0 + RBM=4.0 + RE=0.4 + RC=3 + CJE=5.84E-12 + VJE=0.5 + MJE=0.3083 + TF=340E-12 + XTF=1 + VTF=10.0 + ITF=0.2 + PTF=0 + CJC=5.32E-12 + VJC=0.5 + MJC=0.3271 + XCJC=0.5 + TR=10E-9 + CJS=0 + VJS=1.3 + MJS=0.5 + XTB=2.3 + EG=1.11 + XTI=3.0 + KF=0 + AF=1.0 + FC=0.5 .subckt Q2SA1407 C B E + params: + IC_VCE=1.10250E-36 + IC_VBE=1.10250E-36 + STATE=1 + TEMP=0 + AREA=1.0 + STATE_FACTOR=0 + IS=20.9E-15 + BF=95 + NF=1 + VAF=80 + IKF=0.3 + ISE=0 + NE=1.0 + BR=0.5355 + NR=1 + VAR=20 + IKR=0.5 + ISC=0 + NC=1.0 + RB=5 + RBM=5 + RE=2 + RC=5 + CJE=8.25E-12 + VJE=0.7 + MJE=0.3658 + TF=340E-12 + XTF=1 + VTF=10 + ITF=0.3 + PTF=0 + CJC=7.71E-12 + VJC=0.5 + MJC=0.3964 + XCJC=0.5 + TR=10.0E-9 + CJS=0 + VJS=1.3 + MJS=0.5 + XTB=2.3 + EG=1.11 + XTI=3.0 + KF=0 + AF=1 + FC=0.5 Last edited by homemodder; 8th January 2010 at 09:24 AM. |
#3 |
Thank You Homemodder!
Now the weekend is saved. |
#4 |
Homemodder, where are your models comming from?
If you are arguing with an idiot, first make sure that he is not doing the same thing. |
#5 |
i did a test, end they doesn t work...
is there something missing on the parameters list?? |
#6 | |
This one though I think came from these threads, it was made by SYN08 if I remember correctly, they work fine for me, you have to change them to LTspice format if youre using LT, the details are on the help file. |
#7 |
homemodder, do you have other sanyo models? such as 2SA1538/2SC3953 and 2SA1540/2SC3955?
The response of the inner ear extends to at least 200khz - Dr W. Tempest |
| need 2SA970 Spice Model | Mambo | Solid State | 7 | 23rd July 2010 06:48 AM |
| need spice model 5814a | prorms | Tubes / Valves | 3 | 29th September 2008 12:13 AM |
| Help with ECF80 spice model | 00940 | Tubes / Valves | 0 | 1st November 2007 03:32 PM |
| SPICE model | Prune | Parts | 6 | 16th October 2004 03:22 PM |
| Spice model | doigtee | Tubes / Valves | 6 | 12th July 2003 11:42 AM |
| Page generated in 0.09129 seconds (75.49% PHP - 24.51% MySQL) with 10 queries |
