Old 6th January 2010, 10:57 PM   #1
Havenwood's Avatar
Send a message via MSN to Havenwood
Default Active Load Potentiometer
Hi, I have this potentiometers, cheap and no high quality
What about use this potentiometer as active load in a preamplifier?
I use this circuit
And this is the semi-final circuit, PSpice simulation.
Use cascode in the gain stage.
THD > 0,2%, gain x2, Vout 1Vpp, no global feedback.
Then, I think use a buffer like Dispre I output stage, for example.
No OpAmp like buffer. With unit gain, we have NFB of 120dB (TL082), and I want to try make a preamplifier with no global feedback or very low global feedback.
Opinions? Suggestions? Others ideas?
- Music by John Williams -
Active load output stage croccodillo Tubes / Valves 69 6th May 2012 01:23 AM
A simple active DC dummy load for PSU testing Bootstrapper Power Supplies 42 17th August 2008 08:57 PM
Mu-follower vs common cathode w/- active load jnb Tubes / Valves 7 24th June 2007 09:53 AM
6n1p pre with active load Paracelsus Tubes / Valves 7 24th April 2004 01:03 AM
active plate load v.s. constant current... mwmitchell Tubes / Valves 3 8th August 2002 09:34 PM
Page generated in 0.05836 seconds (77.97% PHP - 22.03% MySQL) with 10 queries
