Old 6th January 2010, 04:03 AM   #1
Default NAD 3225pe amplifier problem
I have a NAD amplifier and need help debugging it.
Old 6th January 2010, 05:15 AM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
OK, I'm listening .....
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 6th January 2010, 06:26 AM   #3
Sorry I had to wait until thread was aproved.
The c511 was damaged and I replaced it (radio shack .1 uf 50v ) also noticed the fuses were blown. but replacing them did nothing as they blew again. What and how should I proceed?
Old 6th January 2010, 06:28 AM   #4
Also I'm in need to learn to repair. so I want to to this DIY way!
I measured the most of the diodes, seem ok (620-640ohms one, way none the other)
How do I measure the transistors as they seem to be the problem?
Old 6th January 2010, 06:33 AM   #5
The Q503 and q504 have big heat sinks
Old 6th January 2010, 06:35 AM   #6
Oh and the symtoms are high distortion, low volume.
Old 6th January 2010, 07:14 AM   #7
Mooly's Avatar
That's the PSU you have posted.... maybe it's a bit early in the morning lol... it's a bit odd.
Which fuses are blowing ?
Do they blow with no speakers connected ?
It looks like the amp runs on a high stabilised supply with a lower higher current supply to "take over" if the output increases beyond a certain point.
Most amp faults see the output transistors fail... either as "just" that or with other damage.
You need to put a mains filament bulb of say 100 watts in series with the incoming supply to allow you to work on it non destructively.
Old 6th January 2010, 07:30 AM   #8
poynton's Avatar
Which fuses blow F501, F502, F503, F504 ??
Old 6th January 2010, 01:31 PM   #9
There is a switch that allows for 4 ohm or 8 ohm operation. All fuses where blown, as I tried changing the position while debuggin.
How ever after reolacing the c501 and fuses, I left the switch on the 8 ohm position and only f503 and 504 blew.
Old 6th January 2010, 01:49 PM   #10
I'm trying to add a better shematic view with no luck. also I have to wait for approval on postings. is there a post limit to be able to post inmediatly or something?
Where do I connect the 100 watt bulb ?
the speakers where installed when this happened.
nad 302 problem (please help!) teknichian Solid State 6 27th August 2008 04:23 PM
NAD 3020 problem vubkevin Solid State 16 11th December 2007 01:08 PM
NAD 3220 PE amplifier problem prerunnerv6 Solid State 2 16th June 2006 05:22 PM
NAD 3020 Problem diddytong Solid State 7 22nd July 2005 04:15 PM
Need help w/ NAD preamp problem Jim B Solid State 13 3rd May 2005 02:41 PM
Page generated in 0.09798 seconds (75.15% PHP - 24.85% MySQL) with 11 queries
