Old 6th January 2010, 12:02 AM   #1
bharfhy is offline bharfhy  Brazil
Send a message via ICQ to bharfhy
Default Initial Project: 300W Power Amp
I found this on Google. power amp 300W
I am very interested in riding. I already started the scheme in KiCad
As I am inexperienced in sound I'd like information from an expert on the quality of the project.
It is worthwhile to mount it or recommend me a better design?
Old 6th January 2010, 01:12 AM   #2
Iain McNeill's Avatar
This is definitely not a first time project. Learning on something that has such power capability is a recipe for electrocution or house fire.
I would recommend something much more simple. Check out Nelson Pass' designs in his forum here or at his website. Also, look at the "chip amp" designs which can sound just as good (not as loud) but are more forgiving for beginners.
Old 6th January 2010, 08:54 AM   #3
Aldotin's Avatar
That's the ETI-466 amplifier (designed by Barry Wilkinson).
This link may help:
ETI-466 Amplifier Technical Review
Old 6th January 2010, 10:47 AM   #4
GK is offline GK  Australia
I've still got all the original magazines featuring these projects. That ETI design wasn't noted for its reliability. The CFP-like output stage with voltage gain was prone to oscillation and smoke. Cloning the design today with modern versions/makes of the same power output devices may even be risky due to the fact that the fT's are likely to be higher than they were back then.
The 300W Playmaster of the same vintage was a much better and stable design:
Electronics Australia Playmaster 300, 300W Amplifier Module
Old 6th January 2010, 11:19 AM   #5
Aldotin's Avatar
Looks like a nice solid design from the 70's era!
For public address purposes it's OK, but as Hi-Fi/audiophile amplifier it's outdated now...
Anyway the Q14-Q16 driver pair seems to be underrated. I'd choose a stronger driver pair - for example the MJE15030/31 pair from Onsemi would do the job!
Old 6th January 2010, 12:46 PM   #6
wahab is online now wahab  Algeria
the only thing thing that is outated are the bjts
wich are quiete old and can be bested by more recents parts..
for the rest, the dual differential proposed in this thread has no
advantages, moreover, the compound output stage is less safe than the
classic one on the australian amp..
Old 6th January 2010, 01:28 PM   #7
Aldotin's Avatar
I referred to the "Playmaster", not the "ETI-466".
Playmaster's OP stage is EF and differential stage isn't dual.
Old 6th January 2010, 01:55 PM   #8
andrewlebon's Avatar
Default playmaster 300 watts
Great amplifier for pa using 4 pairs 2n3773 still going strong built 12 years ago
will post pictures tomorrow can it be modified for higher output using newer
semis
thanking you
andrew lebon
Old 6th January 2010, 02:09 PM   #9
that is a difficult first project.
Start with something much simpler and much lower voltage.
BTW, the 200W into 8r0 is probably right. If the 310W into 4r0 is also correct then it indicates that this is a bad design for a 4ohm speaker.
Don't use it on 4ohm or 4 to 8ohm speakers.
It might work with 6ohm speakers, but you should take the others advice and select a better DIY 200W design as your second or third project.
regards Andrew T.
Old 6th January 2010, 02:26 PM   #10
Aldotin's Avatar
Are you sure?
A 300W/4Ohm rated conventional PA amplifier usually gives ~200W on 8Ohm load.
Ohmite 32 ohm 300W rheostat power resistor boywonder Swap Meet 0 31st May 2009 01:37 AM
need power supply advice for future power amp project. boricuaso Chip Amps 13 6th February 2008 02:24 PM
4 sale or Trade:TAS5261DKD 300w Digital Power amp IC"s!!! Minion Swap Meet 4 18th January 2007 05:05 PM
300W Power Amp bostjancek Solid State 10 7th December 2005 07:35 AM
sam's 300W or eti-466 : power supply bigpanda Solid State 3 1st April 2005 08:17 PM
Page generated in 0.11172 seconds (79.40% PHP - 20.60% MySQL) with 10 queries
