Old 5th January 2010, 06:06 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default a Monstre modification
probably the «Darlington inversé» is the best solution to avoid VAS
File Type: jpg Jean-Hiraga-Super-30W-Class-A-Amplifier-Schematic 2.jpg (123.4 KB, 283 views)
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 6th January 2010, 02:08 PM   #2
Stee's Avatar
Default Eqvilibrivm
Ladies and Gentleman
here the Version "2"
Old 6th January 2010, 03:38 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
I think you meant '2SA1943'.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 6th January 2010, 04:56 PM   #4
tiefbassuebertr's Avatar
a good approach. Now the collector current of the drivers nearly constant (compared to before, where this one at the same time was the base current of the output power devices.
By the way, I want to have a transition to a circlotron by the same basic topology than this circuit for more symmetric behavior and therefore I start this thread some months ago:
Conversion of Hiraga's "Le Monstre" to a Circlotron
But obviously this is more difficult (unlike to a single-stage topology)
Old 6th January 2010, 05:35 PM   #5
Stee's Avatar
Default A1943 is the same generation
BUT the true complementary is the old brother 2SA1903
easy to found near 50hFE with 2SC2500
tiefbassuebertr see this
Old 7th January 2010, 05:19 PM   #6
Stee's Avatar
Default Bigun i'm wrong
the code of generation before 2SA1943
IS 2SA1302
SORRY
Old 8th January 2010, 12:43 AM   #7
bvlabs is offline bvlabs  Moldova
bvlabs's Avatar
Send a message via ICQ to bvlabs
IS 2SA1302
SORRY
And not Hiagra, but Hiraga.
After more matches type of transistors, i born this list below.
2SK246/2SJ103
BC550/BC560
2SA1540/2SC3955
2SA1943/2SC5200
A New Le Monstre Lives Panelhead Solid State 17 7th April 2005 09:07 AM
Noise in Le Monstre Panelhead Solid State 4 26th June 2004 08:00 PM
Le Monstre MikeW Solid State 22 15th May 2004 09:26 AM
Page generated in 0.08228 seconds (76.13% PHP - 23.87% MySQL) with 11 queries
