I've got a rather peculiar problem - while the BUF634 in the library shows up all nice and neat, the one on my PCB has the pads so close together that they're shorting out. Does anyone know what could be causing this?
Here's a picture: ![]() You can download the files here: RapidShare: 1-CLICK Web hosting - Easy Filehosting
I WANT TO BUY SOME W22EX001s. PM me if you have some for sale! |
#2 |
The problem is that the "TO220-5G" package definition in the "burr-brown" library is crap. 1.1mm drill holes with a 1.27mm diameter pad - EAGLE correctly realises that this will not work, and enlarges the pads.
The package TI describe for the BUF634T doesnt really make for leaving much clearance between the pins. This is fine for a professional PCB manufacturer, but too tight for hobbyist development. What I would do here is make a package variant of the BUF634 device that uses the "TO220-5" package that has staggered leads. You will need to bend the leads yourself, but your PCB will be easier to make. A similar chip, Linear Technology's LT1010, has just this configuration. |
#3 |
hi teapot,
I know whats happening but I don't know why? I'll be very interested when someone works it out. The pads are resizing as if they were set to auto. I don't know why it is ignoring the real pad size defined in the library. Look at Tools > DRC > Restring. Pads change size depending on what .drc file is being used. regards
Greg Erskine |
#4 |
I'll admit I'm quite stumped. I'd use the staggered package, but my buffers wouldn't fit (they're actually LME49600s - the pins are too short.)
#5 | |
I prefer my software to do what I want, not what it thinks is right.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| cyrus 2 dead c32 & 31 wrong way help | paul_peraic | Solid State | 0 | 29th May 2008 03:26 PM |
| Wrong Voltage / current on BoZ... or Wrong Measuring ? | gionag | Pass Labs | 8 | 14th May 2008 11:24 AM |
| Mastering eaglepcb | pete.a | Parts | 5 | 3rd December 2007 07:05 PM |
| Sub Amp, what's wrong? | UNDERSTANDIN | Subwoofers | 3 | 25th August 2006 04:38 PM |
| what went wrong with my amp? | Wagener | Solid State | 5 | 25th May 2004 08:11 PM |
| Page generated in 0.08500 seconds (74.11% PHP - 25.89% MySQL) with 10 queries |
