I'm looking to build an amp that matches my loudspeakers, problem is I can't find any info on these speakers on the net; I got them of eBay a few years ago for £5 purely for their looks, but they turned out to be an excellent sounding pair and I haven't used anything else since.
They were sold to their original owner as part of a custom room settup with a TRIO KA-1500 so I guess they must be circa 1979ish which is older than me. I dont even know what impedance they are; They are floor standing, no ports: They are labled Heybrook HB1 And I think this sticker was put on by the system builder: Any info apriciated |
#2 |
Magneto the Gravity Man
I would say they were Dynatrons NOT Heybrooks!
It's typical Dynatron 'style' or lack of it, depending on your tastes! They usually had a fixed cable(through a hole in the back) with a DIN speaker plug. The Heybrook plate looks like an afterthought. : : Heybrook : : The Heybrooks were a highly regarded speaker. Andy .
If it ain't broke, break it !! Then fix it again. It's called DIY ! Last edited by poynton; 3rd January 2010 at 11:42 AM. |
#3 | |
I would ask there: Heybrook spare parts JPW spare parts Linn Isobarik Grilles : : Heybrook : : There are a wide range of the HB1-series. I think, your devices are one of the first released. If you don't get informations about puresound or the new owner of Heybrook, the type No of your transducers are helpful so as images of the crossover network. At newer versions SEAS are inside both by the bass and the tweeter. |
#4 |
I just got this great response back from Guy Sargent from Puresound:
Very odd! It looks as though someone has taken the component parts of a pair of HB1's, ie drivers and crossovers, and fitted them within some (older?) Dynatron wood veneered floorstanding cabinets. The bass driver used in the HB1 was intended for sealed box use and fitting it to a cabinet of a larger volume as this appears to be, will give a little more bass extension. I'm not sure the slots in front of the drivers will be doing the speakers any favours though. The original HB1's had flat open baffles and then used reticulated foam grilles so the dispersion was very good (& unrestricted). The impedance would be around 8 ohms. Bothe the woofer & tweeter were made by Vifa in Denmark and were 8 ohm units. What does tend to fail after 15 - 20 years or so, are the foam surrounds around the edge of each bass driver. Once this happens, bass response deteriorates and as the driver is unable to move in and out in a purely pistonic manner, the voice coil may rub & give the effect of buzzing on some loud notes. Eventually, the insulation is worn through & the driver may short to the chassis or go open circuit. I do regularly supply newly made Vifa M21 drivers to HB1 owners. They are 68 pounds each. It may be worth checking the condition of your surrounds. I've attached a scan of the original HB1 brochure. They were a very popular award winning speaker in the 80's and early 90's. Many thousands of pairs were sold. best rgs Guy Sergeant pure sound That makes some sense because the cabs are extreamly well made, but the cut-out for the connection points is a bit ruff, I always thought that was odd given the general standard of the wood work. Looks like I need to get the screw-drivers out! Thanks All J Last edited by JammyBStard; 3rd January 2010 at 12:08 PM. |
#5 |
#6 | |
The same effect could be a result through the currently condition of surround foam material (only by your SEAS low frequency transducer). In this case you must replace the surround, even if by first look it seems good and not total damaged than of the photo of the following URL http://marktplatz.nordclick.de/Produ...90901-r52.html Independend of this you must replace all old caps from your 3130 integrated amp through such in top quality - this step will greatly enhance the sound quality. Last edited by tiefbassuebertr; 3rd January 2010 at 05:58 PM. |
#7 | |||
Cheers Tief |
#8 |
Anyone know any info about the more modern Heybrook HB1
: : Heybrook : : ![]() I have a pair of their kevlar mids and am trying to work out a sealed enclosure. Many thanks if anyone know anything. |
#9 | |
According to the acoustic conditions and acoustic environment mostly the closed box sounded better (especially if small room sizes are present) and sometimes the vented. This plug from EPOS acoustics consisted of solid foam. If Heybrook don't offer such accessories for their loudspeakers, you must carry out a selfmade device (diy). Last edited by tiefbassuebertr; 17th March 2010 at 02:48 PM. |
| Can anyone give me the specs/Info on these; Haybrook HB1 | JammyBStard | Multi-Way | 1 | 3rd January 2010 12:09 PM |
| Sweep tube info/specs | rsumperl | Tubes / Valves | 2 | 7th November 2009 01:59 AM |
| Akai AM-2850 specs/info | minnister | Solid State | 0 | 28th December 2006 08:46 AM |
| Can someone give me a link to crystal info? | leadbelly | Parts | 0 | 22nd March 2004 02:49 PM |
| Can anyone give more info on this amp? | mg16 | Tubes / Valves | 6 | 8th May 2003 12:43 AM |
| Page generated in 0.12883 seconds (82.62% PHP - 17.38% MySQL) with 10 queries |
