Old 31st December 2009, 03:27 PM   #1
lycanlk is offline lycanlk  Sri Lanka
Default An Old subwoofer amplifier requires a modification
Hi everybody,
I found this sub-amp from an old magazine. Basically it has 4 stages
stage 1 - input buffer
stage 2 - high pass filter
stage 3 - low pass filter
stage 4 - amplification section.
This is the most simplest sub amp i have ever seen. but it has a couple of drawbacks. Actually I dont understand the amplification area but 3 filters are quite simple to me. i want to use my own filters for this. but when I change it the amp is unstable. Can anybody explain the amplification area and any suggestions are most welcome ! I also wants to replace those old drivers and output transistors.
Another major drawback is at stage 1. That is 47K stereo to mono conversion will decrease the input gain when I plug this to my PC. But still I need the stereo input if I try to replace final stage feedback resistors 47k and 1k again the amp will be unstable .. sad sad..
Thank you !
Old 31st December 2009, 04:10 PM   #2
jaycee is offline jaycee  United Kingdom
The output amplification is basically using the opamp as a front end, and then it has a CFP output stage that has gain in order to do voltage amplification.
Not really what I'd call robust enough for subwoofer duty!
Old 31st December 2009, 04:32 PM   #3
nigelwright7557's Avatar
Its not very hi fi, looks like class b so will crossover distortion.
Go for a better amplifier class AB and add the filters on the front end.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 31st December 2009, 07:25 PM   #4
I agree that adding filters to a class AB amplifier will be better.. but can I do it that simple? You can see it uses only a few components. I just want to tweak this by replacing drivers and outputs to handle more power. But I don't know whether it is possible or not ???
Old 1st January 2010, 05:44 AM   #5
dangus is offline dangus  Canada
A chip amp using the inexpensive LM3886 could be as powerful, lower distortion, and more robust. And those can be easily paralleled and/or bridged for much more power.
Old 2nd January 2010, 05:56 PM   #6
Default LM3886 is not that cheep dear friend..
I can buy 3 pair of output transistors for that cost
It also needs more components than this.. but I can see its a good solution if this cannot be modified..
TIP 41c and 42c drives works for this and those are highly available.. any suggestions for outputs with that ???
I just need a simple, high power, low cost and low quality sub amp.. there are many high quality amps in this forum so this time I like to sacrifice the quality for simplicity and low cost.. may be this is a bad idea but take it as a very unique requirement..
Old 3rd January 2010, 04:30 AM   #7
Default This is the PCB if anyone wanna try it..
regards,
Lycanlk
Old 3rd January 2010, 05:14 AM   #8
The problem here is the output stage has gain. If you want to make it more powerful, youll have to start adding pairs. As soon as you start doing this, you make a CFP even more difficult to stabilise.
I might be tempted to suggest the use of MOSFET pairs if you really want more current drive - but you will not get suitable lateral MOSFETs cheap. Verticals will require a more complex drive arrangement and will sound dreadful in class B.
Old 3rd January 2010, 06:33 AM   #9
Default Thanks jaycee..
The problem here is I dont understand the amplification stage and what is CFP ? If you can provide me any source documents to read more about it, pls do.. then perhaps I can modify it myself.. It already has burnt 5 output pairs during tests.. LOL
Lycanlk
Old 3rd January 2010, 09:02 AM   #10
See this link for a more sophisticated version of that design ie op-amp followed by gain stage.
A Paul Kemble web page - PW Texan amplifier and the PE Rondo.
Subwoofer amplifier please at1receptor Class D 0 22nd February 2008 11:54 AM
subwoofer amplifier help at1receptor Solid State 37 18th July 2007 01:51 AM
NS sample now requires a shipping fee ozonek Chip Amps 2 10th May 2007 01:26 PM
SFX Class D subwoofer amplifier modification sagarverma Class D 67 26th June 2006 04:26 AM
Amplifier for subwoofer(s) HoMzE Solid State 1 14th November 2003 02:51 PM
Page generated in 0.11565 seconds (74.55% PHP - 25.45% MySQL) with 11 queries
