Ran into one of these to repair. it is totally dead. no action from the SMPS. Cannot find a schematic or data on this amp. So i am looking for anyone that is experienced in this particular amplifier.
I checked all power and output transistors plus various other components and everything appears to be fine. even replaced the TL494 with a known-good one. dead.... I noticed that TL494 Error amplifier 2 is positive-going true output. thus inhibiting the SMPS from running. negative input i think is pin 15, is a rock 5V from the reference generator. then the positive input pin 16, is sitting around 9V. this causing the output to be 1 from the comparator, and inhibiting operation. I have traced that whole circuit and i am comming up with nothing. If i cross-out pins 15-16 this disabling the comparator, the SMPS will power up, power LED green and no protect LED kicking in either. havent tested for sound, as i didnt want to use it for long with a disabled error amplifier circuit. I guess the error amplifier is used for self-regulation, but im not sure, however that circuit appears to be malfunctioning. any ideas? Last edited by mbates14; 29th December 2009 at 02:47 AM. |
#2 |
Honestly, you can get a new one for 60usd. It is a junk amp, over rated and under powered, this is probaly why you cannot fix it. Power Accoustic tends to use cheap parts but the same chassis for their amps. I would just get another 4 channel with a warranty, not domething someone put together just to make sound. just my opinion, Mavric
#3 |
oh, ill repair it. watch me..... hey however thanks for your opinion anyway...
| Power Acoustik Amp Help | 22chet | Car Audio | 7 | 22nd February 2009 10:05 AM |
| Power Acoustik Amp | chadrock | Car Audio | 28 | 19th March 2008 05:37 AM |
| Power Acoustik A2400db | spooney | Car Audio | 21 | 19th March 2008 12:05 AM |
| Help - JansZen Z-600 - dead step-up transformer? | centaurus3200 | Planars & Exotics | 2 | 5th May 2006 06:35 PM |
| Page generated in 0.07548 seconds (65.66% PHP - 34.34% MySQL) with 10 queries |
