Old 27th December 2009, 01:35 PM   #1
ambed is offline ambed  Latvia
Default p3a dc offset
I have build p3a amp and i measured 16-17mv(20 mv when not warm up) dc offset,does its ok?
Old 27th December 2009, 03:17 PM   #2
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Anything under 100mVdc is usually considered OK. Under 50mVdc is better; so your 20mV is perfectly fine.
AJ
Old 27th December 2009, 04:36 PM   #3
sakis is offline sakis  Greece
sakis's Avatar
-----use beter quality of material (resistors capacitors )
-----match your ltp stage
-----use proper rail voltage
at this circuit and under these rules ofset can be a nice round total zero ....
and yes .... anything that is lower than 100mv ( i would say 50 is better ) is absolutelly not importand
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 27th December 2009, 08:15 PM   #4
nigelwright7557's Avatar
16mV isnt going to move the speaker much or generate much heat in it.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 27th December 2009, 09:12 PM   #5
destroyer X's Avatar
Default 16 mv is almost nothing.
32 microwatts of power (0.000032W)...really you should not worry about.... till 100 milivolts is bureaucratically considered fine.... usually factories suggest you to produce some adjustment when the off set is bigger than 25 milivolts.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 14th January 2010, 05:07 PM   #6
can yo tell your opinion about this pcb layout??maybe there are some mistakes or somthening that .....
Old 14th January 2010, 05:10 PM   #7
I might have added a ground plane if your pcb software allows it.
Failing that just thicken up tracks as much as possible.
Old 14th January 2010, 05:41 PM   #8
Bone is offline Bone  United Kingdom
Ambed, Q9 the transistor which determines the bias current, needs to be mounted in contact with either Q5 or Q6 as these transistors determine thermal drift not the output pair. It should not be mounted on the main heatsink.
Old 14th January 2010, 06:24 PM   #9
Rod Elliot doesn't say so in his project outline.
AJ
Old 14th January 2010, 06:26 PM   #10
Did it Himself
richie00boy's Avatar
Bone is right. Rod probably doesn't mention it as his PCB is laid out correctly already.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
DC Offset JannaCassandra Chip Amps 3 26th July 2008 03:20 PM
What is DC offset? spooney Car Audio 13 2nd March 2008 10:35 PM
DC offset in my p3a- need help! dmitriy167 Solid State 6 14th January 2005 12:14 PM
Help With DC Offset Sybex23 Chip Amps 8 15th November 2004 07:11 PM
DC offset need help again :-( djdamix Solid State 13 26th October 2004 08:38 AM
Page generated in 0.09925 seconds (75.52% PHP - 24.48% MySQL) with 11 queries
