Why am I getting a positive phase shift Why am I getting a positive phase shift - Page 3 - diyAudio
Old 29th December 2009, 09:36 AM   #21
godfrey is offline godfrey  South Africa
Seems to me there's a nice option with Allison-biased Mosfets.
If you you drive the Allison at the emitters and use bootstrapped current sources, then you can get close to rail-to-rail output voltage swing because the gates can be driven beyond the supply rail voltages.
Old 29th December 2009, 09:52 AM   #22
To get close to rail-to-rail output swing in class B, one could perhaps use something like this?
Old 29th December 2009, 04:31 PM   #23
keantoken is offline keantoken  United States
keantoken's Avatar
All this depends of what Sig wants.
In your Allison thread, the image in the first post won't expand , so it's hard to see what's going on.
I attached a zip file holding the schematic and files for that experiment at the bottom, if you can use LTSpice. I'll look for the image.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Why am I getting a positive phase shiftHide this!Advertise here!
Phase Shift PWM Andrew Eckhardt Class D 6 14th November 2010 07:56 AM
phase shift of second order filter bondo Multi-Way 9 8th April 2009 02:24 AM
Phase shift smps topology darkfenriz Power Supplies 12 10th August 2008 11:30 AM
Zero phase-shift gareth Solid State 11 9th May 2008 04:45 PM
Creating positive phase shift? Pabo Class D 31 14th January 2005 06:44 AM
Copyright ©1999-2017 diyAudio
