I turned on my Aragon 24k the other day and a very loud pop came through the speakers. (Normally if I turn on the preamp and amp out of order there is a very soft pop.) The right channel was also very low.
The loud pop also occurs when switching from On to Mute and when shutting off the preamp (the power switch goes Off-On-Mute). None of the components have visibly failed and the readings across the transistors are consistent. Any ideas what may be wrong? |
| LM1875 power on POP problem | AndrewGM | Chip Amps | 6 | 16th May 2009 04:40 PM |
| Peak voltage output of a Aragon A2D2 DAC? | G | Digital Source | 0 | 16th January 2008 04:54 PM |
| power supply problem pop noise | prorms | Solid State | 5 | 11th September 2007 11:15 PM |
| Value of output caps for Aikido - how low is too low? | cbutterworth | Tubes / Valves | 9 | 3rd September 2007 01:34 AM |
| Need help with IC Based Amplifier "pop" problem (Integrated Component) | Monolith | Solid State | 7 | 13th March 2003 03:01 PM |
| Page generated in 0.06339 seconds (68.05% PHP - 31.95% MySQL) with 10 queries |
