Audio Junkie
I am looking for some Thick TO-220 Ceramic Insulators. I am working on an amp that uses these 2-3mm thick ceramic pieces as insulators. some of them are broken and i need to replace them. I have only seen the mica, kapton or sil-pad type insulators.
Anyone have a source for these?? They must be using these thick insultors due to the high voltages involved. many of these parts have 440V on them and or 70khz high frequencies. Zc Last edited by Zero Cool; 21st December 2009 at 07:21 PM. |
#2 |
Sure, just search for aluminum oxide.
Digikey sure has them. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#3 |
My mistake.
Farnell is where I saw them: AAVID THERMALLOY|4180G|Thermal Insulator | Farnell Danmark Magura
#4 |
Let's hope the ones you have are NOT beryllium oxide. DO NOT broke them into pieces and create dust. It is POISONOUS. Better to use Aluminum oxide or kapton-like (K-10) or sil-pads. See Digikey for examples of this. Use the one with the lowest thermal resistance.
#5 |
Audio Junkie
The ones i have are white ceramic. they were broken when i removed them. the second i loosened the screw, the broken pieces fell out.
Zc |
#6 |
You are probably looking for the beryllium oxide type. I stocked up on the TO-3 type a few years back, got them from Hosfelt Electronics in OH. I found the part number on the Thermalloy or Wakefield site, then searched that number and came up with Hosfelt. They ARE the best if you have to use an insulator. I also bought a torque screwdriver so I don't break them, 6 in/lbs is all that is needed for TO-3s. You can download a whitepaper from ON Semi about transistors and mounting, also the torque specs for all types of transistor cases. Yes they are poisonous so take heed and don't stick 'em in your nose or mouth. I used many of them in the military and I'm still kickin', for now at least. I'm using them on my Sumo Andromeda II rehabbed into a Pass A40.
Craig |
#7 |
Digikey has all of the part numbers for the Thermalloy aluminum oxide insulators but none in stock and very high minimum order. Use the part numbers and search the internet. I couldn't find them on the Hosfelt site now.
Craig |
#8 |
Just found some aluminum oxide type for TO-220 at Mouser, in stock at a whopping 50 cents each. Part number 532-4170.
Craig |
| WTB: Small qty. TO-3P insulators (US only) | sonidos | Swap Meet | 17 | 31st December 2010 01:54 AM |
| WTB: BUF-634 buffers in TO-220 package | KT | Swap Meet | 1 | 24th July 2007 05:15 AM |
| WTB: FELT F13 Grey - 1/4" to 3/4" Thick - Like on Duntech/Dunlavy Speakers' Baffle | dtm1962 | Swap Meet | 0 | 21st October 2006 04:18 AM |
| WTB: 240 V transformer for Hafler DH 220 | al2002 | Swap Meet | 0 | 26th June 2005 08:08 PM |
| WTB: 2 pcs. Elna Cerafine/Black Gate ~220+220uF/350V | reaction | Swap Meet | 0 | 29th October 2004 08:14 PM |
| Page generated in 0.08097 seconds (80.12% PHP - 19.88% MySQL) with 10 queries |
